Simple Problem (I t...
[Closed] Simple Problem (I think!) - Fitting New Cables
6 Users
Fitting new cables and have removed old ones. Have threaded new cable through the shifters, through the housing and through the rear mech and tightened. However, when I move the gear shifter the rear mech does'nt move - what have I done wrong? (old XT shifters and XTR rear mech)
I'm sure there's a simple solution but...
Posted : 08/11/2009 2:24 pm
is there any tension on the cable when you click the shifter??
did you thread it correctly through the shifter??
Posted : 08/11/2009 2:28 pm
 Goz
Is the cable nipple located in the correct position in the lever, it sounds like youve installed it incorrectly.
wow- very fast replies
when you say is the nipple in the correct postion, you mean?
and no, there's no tension
Posted : 08/11/2009 2:29 pm
ATGNI? 😉
Posted : 08/11/2009 2:32 pm
 Goz
Reverse rise mech?
no just ridden bikes for almost 20 years and never learnt how to service them, now I'm starting, but cheers for the postive comment sofatester 😉
Posted : 08/11/2009 2:34 pm
Anytime Hitman 😀
Posted : 08/11/2009 2:37 pm
get a grown up fix it for you 🙂
Posted : 08/11/2009 3:50 pm
Undo the cable from the mech and hold it in your hand, pulling on it. Shift with the shifter - can you feel the cable getting pulled through? If not, then either the cable isn't installed in the shifter right, or the shifter is screwed?
At a guess.
Posted : 08/11/2009 5:41 pm
