Silly Sram 11 speed...
[Closed] Silly Sram 11 speed cassette question!!!!
4 Users
Hi
I am sure I should know the answer to this but can I run a Shimano 11 - 42 cassette with my Sram Force CX1 11 speed I have a 11 -36 cassette at the moment and am having trouble on a few Cotswold hills?
Thanks
Posted : 29/03/2016 8:14 am
You'll need a new freehub body and a new rear mech - CX1 won't like the range. Probably cheaper to go 2x11 with your existing mech and cassette!
Posted : 29/03/2016 8:23 am
Thanks for the quick response but doing that I would have to buy a new shifter, crank, front mech and special mech hanger.
If it can not be done I will have to get a smaller front chain ring but I like the low gear I have at the moment.
Thanks
Posted : 29/03/2016 8:32 am
If you're running CX1 11 speed at the moment it'll depend on which length CX1 mech you're using. The long cage should allow you to run a 10-42 SRAM cassette so shouldn't have any problems with a Shimano 11-42.
Posted : 29/03/2016 8:46 am
Doesn't CX1 use shimano road pattern 11 speed splines, not XD? So just a matter of getting an MTB 11 speed cassette and a spacer. (If the cage is long enough)
Posted : 29/03/2016 8:55 am
Aaah, that'll teach me to reply quickly!
11-42 will of course not need a new freehub body (I read SRAM 10-42), but you will need a 10/11 speed spacer because of the aforementioned longer 11-speed road specific freehub body versus a mountain bike 11-speed freehub body which offsets the largest sprocket to achieve the same result.
On rear mech length I was just wrong - I was thinking SRAM were like Shimano, and that all road groups/CX1 came in short/medium, didn't realise there was a long, which will of course be ok, if it's what you have.
So the answer is 'maybe', but you can completely disregard what I said this morning!
Posted : 29/03/2016 1:39 pm
