The manual for my BOS forks say to use a silicon-based oil. Now, I have used Fork Juice in the past, but I've read in a number of places that uses a spray doesn't do the seals any good.
Any recommendations for a light, silicon-based, non-spray, oil to use?
tri-flow
[url= http://www.quicksarchery.co.uk/superbasket/product/2861/MA50+Tri+Flow+Lube.%3A+ ]here[/url]
Tri Flow doesn't appear to be silicon based. At least it doesn't say it is.
MSDS for tri flow says no ingredients are harmful so I would say that rules out silicone.
You can get silicone oils but quite easily.
ow, try googling silicone shock oil, not bike specific but looks to be the stuff
I did
Fork juice is silicon based. Stop worrying. It's what I use on my BOS fork and shock with no problems to report. All it does is help lift dirt off the seals and make them a tiny bit smoother.
+1 for just use Fork Juice.
+ 1 for Brunox
I use [url= http://www.ebay.co.uk/itm/SILICONE-SPRAY-500ML-FOR-BIKE-CAR-TREADMILL-SQUEAKS-/190848055180?pt=LH_DefaultDomain_3&hash=item2c6f6e378c ]this...[/url]
I'd heard that these kind of sprays are great for killing of stanchions as the dust/dirt to mix with the oil and form a nice grinding paste. Would be happy to hear that this is not true though.
fork juice, even just for the smell
paul123 - Member
This is not true!
Clean Stanchions, apply SILICONE lube (not GT85, WD40 or TF2 whatever it is), cycle fork a few times, wipe off excess - simples!
Cleaning/lubing stanchions should be part of your cleaning/maintenance schedule 😉
