SIDs versus Rebas
[Closed] SIDs versus Rebas
5 Users
Could anybody talk me through the main differences between SIDs and Rebas? I am pricing up a 29er build (EMD) and I have found SIDs nearly as cheap as the Rebas. I usually buy Fox and I don't know much about Rockshox or XC forks in general.
Thanks!
Posted : 03/02/2012 12:46 pm
Which SIDs? They come in a variety of flavours. SIDs are about 100g lighter and perhaps more tunable. Both can be internally adjusted to change the travel. I have REBA RLT 2011 29er forks with 80mm of travel. Probably more durable than SIDs as well.
Posted : 03/02/2012 1:03 pm
SIDs are lighter, REBAs are stiffer. (In a nutshell, anyway).
Posted : 03/02/2012 1:15 pm
schmiken - +1 Basically if you want a stiff fork then you want the reba's. If you can get a SID with 15mm or 20mm then I would go for that.
Posted : 03/02/2012 1:22 pm
But the sram website quotes almost identical weights. I went for rebas on my 29er for stiffness and they were available in maxle. Not sure if stiffness is a big issue for bigger wheels and so longer forks but my basic physics says longer things flex more easily. Maybe...
Posted : 03/02/2012 1:26 pm
I have done a bit of research and the weights seem similar. The Rebas are RLT Dual Air with Maxle and Pushlock for €499, the SIDS have the Maxle and DNA RTC3 damping but no Pushlock for €549. Unless I find some good reviews of the RTC3 I will probably just go for the Rebas.
Posted : 03/02/2012 3:38 pm
