Having just put some new tyres on the tandem to replace the ageing Conti Verticals, I decided it was a good excuse for a thread.
The bike is a slightly old Ventana El Conquistador de Montanas (just as well it has a long TT!) with Fox 36s, Middleburn cranks , Magura Louises (that I want to get rid of and swap for Saints), and DT/Magic wheels. Rides brilliantly and is so much fun!
Last ridden at Battle on the Beach, and now clean and ready to ride:
Slam that stem!
Looks great 🙂
Is that some kind of puncture repair doohickey attached to the stoker's stem? And who operates the rear v-brake?
Don't have a tandem, always fancied one! 🙂
Yeah, it's a can of sealant, placed ready for BotB that I hadn't removed. The rear Vbrake is attached to a thumb shifter which the captain operates - you can see it by the LH grip in the second picture.
In full on expedition mode
[url= https://c1.staticflickr.com/4/3848/33428894330_937d1686a4_k.jp g" target="_blank">https://c1.staticflickr.com/4/3848/33428894330_937d1686a4_k.jp g"/> [/img][/url][url= https://flic.kr/p/SVZPD5 ]IMG_2657cropped[/url] by [url= https://www.flickr.com/photos/25846484@N04/ ]TandemJeremy[/url], on Flickr
Posing by the beach[url= https://c1.staticflickr.com/9/8142/7233525464_1aeea72126_k.jp g" target="_blank">https://c1.staticflickr.com/9/8142/7233525464_1aeea72126_k.jp g"/> [/img][/url][url= https://flic.kr/p/c2cH7h ]07 beach and bike[/url] by [url= https://www.flickr.com/photos/25846484@N04/ ]TandemJeremy[/url], on Flickr
Might be up for sale soon as we don't really use it much any more. 🙁
[url= https://c1.staticflickr.com/7/6208/6039241084_f4c14df794_b.jp g" target="_blank">https://c1.staticflickr.com/7/6208/6039241084_f4c14df794_b.jp g"/> [/img][/url][url= https://flic.kr/p/acEFYh ]110813_132922[/url] by [url= https://www.flickr.com/photos/stu-b/ ]multispeedstu[/url], on Flickr
'Multispeedstu' 😆
Ours is like schmiken's, just a slightly/substantially older version. Still the same blue though, and still going strong 🙂
Wonder if this will work?
[url= http://i.imgur.com/qOTKDJi.jp g" target="_blank">http://i.imgur.com/qOTKDJi.jp g"/> [/img][/url]
It's a blue Ventana love-in tonight on STW!! Here's Nancy-
[URL= http://i41.photobucket.com/albums/e253/RobCooksley/IMG-20121006-00541.jp g" target="_blank">
http://i41.photobucket.com/albums/e253/RobCooksley/IMG-20121006-00541.jp g"/> [/IMG][/URL]
She's had a shorter stem since that photo. Homebrew drivetrain using 22t timing rings for max ground clearance, and a DIY remote lockout on the RP23 driven off a gripshift on the stoker handlebars (because Sandy can't reach the Propedal lever!).
And a wee run down the Glentress freeride park-
[URL= http://i41.photobucket.com/albums/e253/RobCooksley/nancyfreeride.jp g" target="_blank">
http://i41.photobucket.com/albums/e253/RobCooksley/nancyfreeride.jp g"/> [/IMG][/URL]
Rob & Sandy - who are pretty gutted Tweedlove won't let tandems enter the Enjoyro 🙁
rob and sandy - claim disability discrimination? 😉
Our mtb one in its current guise, ready to be ridden in the Surrey Hills last weekend, Rohloffed with 29plus front with a 2.6 Nobby Nic on the back, our fourth mtb tandem, love it in this setup.
No pictures of our roadie tandem but stock Dawes but with Avid BB7s front and back.
@Schmiken - what's the thinking behind running two brakes on the back? And how do you operate it with the lever - does it click through steps like a shifter or is it more gradual?
bugpowderbust - single sided drive with the rohlf? I couldn't get this to work on ours - the chains clashed if I put the two rings on the middle and outer position and I didn't want to use tiny granny ring timing rings - also the chainrings covered the bolt for the front wedge eccentric - how did you get around this?
Tjagain - can still get to the eccentric bolt as using a direct mount ring on a race face aeffect crank then same setup on the rear but with a 3x spider on the same crank and then narrow wide rings. It's tight and some foliage gets wedged in the gap but works really well.
@upshift - the stock brakes tend to heat up and fade rapidly when dragging the brake downhill to scrub speed, so a V brake just applies some drag force to slow us down as the wife can be a bit nervous. Works really well and isn't indexed.
Here's our Hase at Lydford castle a couple of days ago...
I heard they had low gears but didn't realise they could literally climb walls 🙂
@Schmiken - I figured as much. Not seen it before but makes perfect sense!
No idea why it's displaying like that. Awesome toy though.
Another ECDM
[img] https://c2.staticflickr.com/6/5650/22025416096_cdc13b6ae8_c.jp g" target="_blank">
https://c2.staticflickr.com/6/5650/22025416096_cdc13b6ae8_c.jp g"/> [/img]
