show me youre 1x11 ...
[Closed] show me youre 1x11 setup with weights
28 Users
[url= http://imgur.com/MqLWY9c ]Show me youre 1x11 setup with weights [/url]
Posted : 23/02/2014 10:23 am
[URL= http://i.imgur.com/MqLWY9c.jp g" target="_blank">http://i.imgur.com/MqLWY9c.jp g"/> [/IMG][/URL]
Posted : 23/02/2014 10:25 am
The missus bike
Tallboy Alloy
25.65lbs / 11.71kg out the box
Changes to date Reverb in and about 3cm of carbon bar out and going between Ikons and Ardent Races. Accompanied by some CB Candy 11's
Posted : 23/02/2014 11:59 am
Very nice indeed , my Remedy 9.9 came with the alloy remedy 9 build kit .ive put a reverb stealth on , carbon haven bars , for the summer I'll be using these stans no tubes crest wheelset at 1440g tubeless with bonty xr3 and xr2 tyres also a SDG Falcon Ti saddle.And just fitted a X01 groupset with the xx1 cassette. All in without pedals 24.9lbs/11.29kg 🙂
Posted : 23/02/2014 12:23 pm
Thats a vry light bike from stock 🙂
Posted : 23/02/2014 12:24 pm
not disbelieving you but I'd like to see it on the scales at that!
I prefer my trail bikes with a little more beef to them than that too!
Posted : 23/02/2014 12:30 pm
That's fine I will get myself on the scales again and show with and without weights post back in a few days as im at work.
Posted : 23/02/2014 12:52 pm
For a little more beef I will be swapping the wheelset out , for some hope pr 2 evos with arch ex for allday use .
Posted : 23/02/2014 12:54 pm
Have posted pics in the 'show me your Enduro etc' thread but just picked up a medium Pivot Mach6 that comes in at 12.2kg, sorry, on my iPhone so too much hassle to link pics.
Posted : 23/02/2014 1:37 pm
Hi this is my first pic post on here too . I went to imgur.com uploaded photo no need to register, then copied and pasted hope this helps.
Posted : 23/02/2014 2:24 pm
Krampus + Tallboy - the tallboy has been through 1x xx1 drivetrain already due to low maintenance
[URL= http://i1272.photobucket.com/albums/y394/dansipods2/image-27_zps86907812.jpe g" target="_blank">http://i1272.photobucket.com/albums/y394/dansipods2/image-27_zps86907812.jpe g"/> [/IMG][/URL]
Posted : 23/02/2014 2:45 pm
Very nice 🙂
Posted : 23/02/2014 2:59 pm
did this in 1500ish miles, same chain, no maintenance, apart from chainlube, cassette also finished in some gears,
Posted : 23/02/2014 3:07 pm
dirtyrider - do you think this has worn too early or are you OK with this after 1500 miles?
Just wondering, 1500 miles is a fair amount off-road if conditions are mucky, the equivalent to an entire years riding once a weekend at 30 miles a pop.
Reason I ask is my works components one probably has 800 miles or so on it now and still looks to have lots of life left in it, I have popped a new chain on once though - a stretched chain cant help.
Did the chain still stay on btw?!
Posted : 23/02/2014 3:11 pm
Wow im no expert ive only just put the X01 groupset on my Remedy. But I do ride in an area were its like grinding paste in the wet, so judicious cleaning is required post ride on the drivetrain.ive never seen that amount of wear on a drivetrain to be honest.good job you can buy the jockey wheels seperate .
Posted : 23/02/2014 3:18 pm
chain never dropped, i was fine with the wear vs mileage considering the lack of maintenance
Posted : 23/02/2014 3:19 pm
My Horsethief comes in at 29 lbs with 34s and Flows:
Have done about 800 miles on the drivetrain with no significant signs of wear but I do endeavour to keep it very clean (motivated by the cost of a cassette!).
Posted : 23/02/2014 3:40 pm
Im liking it 🙂
Posted : 23/02/2014 3:51 pm
Slightly OT but dirty rider are those 140mm 34s on your tallboy? I was wondering if I'd get away with fitting 140mm pikes to mine
Posted : 23/02/2014 4:15 pm
19.2lbs:
Posted : 23/02/2014 9:21 pm
Worth changing the chain regularly? Assume chain checkers work the same? Next bike coming soon will 1 x 11
Posted : 23/02/2014 9:31 pm
If only to increase the lifespan of the cassette I'd say so.
Posted : 23/02/2014 9:33 pm
njee, you could get that down to 19lb easy and it wouldnt cost a penny.
Cut your steerer 🙂
Posted : 23/02/2014 9:39 pm
Ha! May change the fork, so not gonna cut it quite yet, head tube isn't particularly long!
Posted : 23/02/2014 9:43 pm
No, I dont blame you, it does look short!
Posted : 23/02/2014 9:44 pm
Im liking the Stache lots 🙂
Posted : 24/02/2014 8:14 am
12.28kg with pedals, I imagine that if I had spent a little more on carbon rims it could come down more but its probably cheaper, and better, to save weight by going on a diet.
Posted : 24/02/2014 11:40 am
No longer mine but it was 29lbs
Not mine but it was 29lbs
My XX1 groupset is awaiting it's new home...
Posted : 24/02/2014 12:30 pm
Not quite 1x11.....XX1 cranks with a General Lee adapter. It was just over 30lbs with a Fox 34 fork and XT cranks, so should be 29lb something with Pikes and XX1 cranks.
[URL= http://img.photobucket.com/albums/v492/pablo16v/IMG_000003421_zpsc4917856.jp g" target="_blank">http://img.photobucket.com/albums/v492/pablo16v/IMG_000003421_zpsc4917856.jp g"/> [/IMG][/URL]
Posted : 24/02/2014 1:08 pm
All very nice indeed 🙂
Posted : 24/02/2014 7:21 pm
Posted : 28/02/2014 4:14 pm
That was for my original post of my remedy 9.9 no pedals
Posted : 28/02/2014 4:20 pm
Here's mine, gone down the three chain route 😉 , we shall see if it works. 12.7Kg ish. Not been on the scales but standard is 12.6Kg. Less tubeless, plus pedals 304g,plus Rockguard mudguard,less lighter seat.So 27.5 pounds ish, with dropper post, proper tyres and 160 front 150 rear.[img][URL= http://i.imgur.com/BdBFHx4.jp g" target="_blank">http://i.imgur.com/BdBFHx4.jp g"/> [/IMG][/URL][/img]
Posted : 28/02/2014 7:34 pm
Slightly off topic but what spokes and lengths did you use on those wheels Njee20?
American Classic on light bicycle beadless rims?
Thinking of building some wheels with the same parts!
What weight are they coming in at?
Thanx,
Max
Posted : 28/02/2014 9:17 pm
Yetiman, is that the Peak district?
Posted : 28/02/2014 10:02 pm
27.8lbs:
[URL= http://img.photobucket.com/albums/v444/RickDraper/Cycling/IMG_3355.jp g" target="_blank">http://img.photobucket.com/albums/v444/RickDraper/Cycling/IMG_3355.jp g"/> [/IMG][/URL]
Posted : 01/03/2014 1:06 am
29lbs
[URL= http://i777.photobucket.com/albums/yy58/generallevi/Mobile%20Uploads/C85DFFB5-F776-4618-BF6F-EBA53FA7CAF0_zps4ynhhtx5.jp g" target="_blank">http://i777.photobucket.com/albums/yy58/generallevi/Mobile%20Uploads/C85DFFB5-F776-4618-BF6F-EBA53FA7CAF0_zps4ynhhtx5.jp g"/> [/IMG][/URL]
Posted : 01/03/2014 7:40 am
 Rik
Think someone (well most people on this thread) have got their imaginary magical weighing scales out again.
There is no way that the two bikes above are only 1lb and bit different! The Santa Cruz even has sub 500g cranks on.
Posted : 01/03/2014 9:16 am
28.41lbs measured on digital scales. This is Fitted with sdg ti fly saddle and renthal carbon bars since photo.
Agree with above post some of the weights listed are a bit optimistic, but hey as long as it rides light 😉
[url= https://farm3.staticflickr.com/2850/9581797643_c3692a95d9.jp g" target="_blank">https://farm3.staticflickr.com/2850/9581797643_c3692a95d9.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/80802903@N08/9581797643/ ]Enduro cwmcarn[/url] by [url= http://www.flickr.com/people/80802903@N08/ ]dan45a[/url], on Flickr
Posted : 01/03/2014 11:52 am
My Remedy 9.9 is a full carbon frame fitted with easton carbon haven bar , sdg falcon ti saddle , xo1 groupset apart from the cassette wich is xx1.the wheels on her are stans hubs with crest rims with are laced with DT revolution spokes 1440g a pair .ive gone tubeless using bonty xr3 and xr2 tyres these are both sub 600g tyres. So my weight of 24.11 lbs is factual withought pedals 🙂
Posted : 01/03/2014 6:52 pm
 DanW
factual without pedals
My bike is about 6.5kg without forks, saddle or seatpost 😉
Only cure for the criticism is a scale shot (Park/ Alpine/ other decent non-ebay £5 scale) with the bike as ridden. If you ride with ton of heli-tape/ Garmin/ lights/ whatever that should be included IMO
I'll post up my Scalpel when I get pics (XX1 and some nice modifications to drop the weight of the stock groupset).
Posted : 01/03/2014 7:15 pm
@Rik
Weighed with a calibrated Park Tools scale. Your probably thinking that those Enves weigh a lot less than my Crossmax wheels but there is only 100g in it. Also, why couldn't I get a rune under 30lbs when the designer Keith Scott speaks openly that he has seen them down a 27lbs with a lightweight build?
I am not a liar mate. You will find most runes around the 31lbs mark but this one has carbon bars, xx1, light wheelset and xo trails.
If anything the Santa Cruz should be closer to 26lbs.
Posted : 01/03/2014 8:11 pm
 Rik
Enve quote them being 200g difference to mavic
Frame, chainset, shock, saddle, brakes, tyres etc etc are all lighter than your bike. So one of the bikes bike has been weighed wrong.
Posted : 01/03/2014 8:24 pm
@Rik
How do you know that's it's 200g when you don't even know what hubs he's running?
At the end of the day, I know how much my bike weighs. I don't know why you should be so shocked that an aluminium framed bike can dip just under 30lbs with an xx1 build and decent wheels.
Posted : 01/03/2014 11:03 pm
generallevi - Member
@Rik
Enve kit is a standard option on the SC and their Mavic on Mavic hubs. (from the pic)
Posted : 01/03/2014 11:05 pm
@mikewsmith
I know they are Mavic on Mavic dude as it's my bike! My point is depending on what hubs that Santa Cruz has will have an effect on the overall difference between the two wheel sets. As durable as king are they are a lot heavier than a DT Swiss build, for example
Posted : 01/03/2014 11:24 pm
Taken directly from the Enve website:
WEIGHT: KING ISO*
1602g
WEIGHT: DT 180*
1420g
WEIGHT: DT 240 15mm/142*
1515g
Weights taken from Mavic website:
Weight : 1660 grams (pair of wheel)
So if your man is running his Enve's with King then as I said there's less that 100g in it, well 58 actually. Not bad considering you could get three pairs of mavics for the price of 1 pair of Enves. They do look mega though! 😉
Posted : 01/03/2014 11:38 pm
Here are my two, I've got no idea how much they weight though....
[url= https://farm3.staticflickr.com/2862/12878119963_f20e94910d_o.jp g" target="_blank">https://farm3.staticflickr.com/2862/12878119963_f20e94910d_o.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/118973368@N08/12878119963/ ]IMG_0076[/url] by [url= http://www.flickr.com/people/118973368@N08/ ]AndyBeirne[/url], on Flickr
[url= https://farm3.staticflickr.com/2888/12877757654_9e10fba454_o.jp g" target="_blank">https://farm3.staticflickr.com/2888/12877757654_9e10fba454_o.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/118973368@N08/12877757654/ ]IMG_0040[/url] by [url= http://www.flickr.com/people/118973368@N08/ ]AndyBeirne[/url], on Flickr
Posted : 02/03/2014 2:08 pm
not usually jealous of bikes on here, but that jones is magnificent! will get one eventually!
Posted : 02/03/2014 3:18 pm
I'm sure you all know manufacturer weights are optimistic at best and a complete lie at worst. Time after time i've weighed something and it's been over the quoted manufacturer weight, often by a fair bit. For example RS quotes a 2011 Revelation RLT Ti (dual air) as 1636g. When i got mine the steerer had been cut and it weighed 1800g on the nose.
So by the time you've added up the (optimistic) manufacturer weights of all your parts you'll have a bike that on paper weighs at least a few hundred grams, maybe an entire pound, less than it actually does.
Or didn't you realise you were being lied to?
Posted : 02/03/2014 3:37 pm
I must have picked better parts and spec lists 🙂 I planned my last build that way and there was 300g difference which went down for cables and some other misc bits.
Posted : 02/03/2014 9:25 pm
You must have the bestest specced bike ever
Posted : 03/03/2014 9:21 am
Santa Cruz quote 5.3lbs for a Bronson C frame with Fox CTD
Banshee were quoting 8.5 lbs for a Rune with CCDBa when I was looking to buy one.
100g one way or the other on wheels is small potatoes if there's a 3.2lb difference in frames. Banshee has heavier wheels, heavier tyres,and heavier cranks. Not sure where the weight savings can be coming from to get it within 1lb of the Bronson
Posted : 03/03/2014 9:48 am
bomberman - Member
Just the ones that have the right quoted weights, I'm finding most modern stuff quoted properly just there is still some stuff sneaking in - like forks specced with heavier steerers etc.
Posted : 03/03/2014 10:17 am
The Jones is lovely! With I had the beans to make mine xx1.
Posted : 03/03/2014 10:18 am
c_klein87 - Member
Thanks, I'm really over the moon with how it turned out.
futon river crossing - Member
The XX1 on my other bike has been great and I love having a gripshift again. I went with a trigger shifter on the Jones though after getting advice from Jeff.
Posted : 03/03/2014 10:24 am
Tyres filled with helium.
FACT.
Posted : 03/03/2014 10:48 am
This is my 5 spot, 29.5 Lbs apparently.
Posted : 03/03/2014 11:15 am
Like that 5 spot.
Posted : 03/03/2014 4:21 pm
bomberman - Member
Really, and how can you tell if a part has the right quoted weight? By looking at it I suppose?
Posted : 03/03/2014 4:47 pm
 br
[i]I'm sure you all know manufacturer weights are optimistic at best and a complete lie at worst. Time after time i've weighed something and it's been over the quoted manufacturer weight, often by a fair bit.[/i]
Rode with a chap that had just picked up a new carbon Whyte 29er FS.
It felt light to pick up. 26.5lbs he said it weighed, according to Whyte.
I suggested he try me Ti HT, "that's light", says he "what's it 22, 23lbs?"
Nope, 26.5lbs on my (Park) scales 🙂
Posted : 03/03/2014 5:17 pm
Mostly by dropping it on some scales... I was making the judgement based on that and having done 3 builds where the sum of the quoted weights added up to the weight of the bike.
Posted : 03/03/2014 9:08 pm
Oh so like, equations and stuff?
b r what did his face say? Was he surprised?
Posted : 03/03/2014 11:57 pm
@honourablegeorge
As iv already said earlier in this thread if anything that Santa Cruz should be coming in lighter, closer to 26lbs than where it is up near 28.
I am not saying that there can't be more than 1lbs between the two bikes. What I am saying is that I have weighed mine twice, in my mates shop and at home and it's coming in at 29lbs. My friend is the mechanic at Bike Park Wales and has just build up a rune with an identical spec to mine but in black instead of green and it's coming in at something like 29.04 or the like. He is on this forum so will get him to put pics up.
I think the edges are getting blurred here. The initial discussion for me in this thread is not the fact that there is just over a pound between the two bikes, that's open to discussion. It's the fact that someone called me out and said my measurements are off, which they are not. The bike is under 30lbs. 🙂
Posted : 04/03/2014 7:15 am
If that banshee weighs 29lbs my Enduro must about 26 😉
Posted : 04/03/2014 7:37 am
 br
[i]Santa Cruz quote 5.3lbs for a Bronson C frame with Fox CTD
[/i]
It shows how I can get mine down to 26.5lbs with 3x9, big tyres, pedals, dropper, cruds and light-brackets - as my frame is only 3.5lbs. For a 20". 🙂
Posted : 04/03/2014 8:15 am
Thanks B R.
A much heavier Bronson build coming in at 26.5, which shows that this Gucci version up the page has to be even lighter.
And honourablegeorge the frames were redesigned for 2014 and weight was dropped off in several places, according to the designer. Loss was around 1lb so your frame quote of 8.5 lbs only applies to the 2013 frame.
Posted : 04/03/2014 9:55 am
