Show me your Specia...
[Closed] Show me your Specialized Enduro external dropper routing
5 Users
Hi folks. Ca anyone who has an Enduro with external dropper post routing show me a pic to help set mine up. I have a seat clamp with a guide built on but that just seems to make the cable curl directly under the seat
Posted : 10/05/2016 6:55 pm
What year Enduro.
Posted : 10/05/2016 7:03 pm
Posted : 11/05/2016 7:01 am
Our 2015 Enduros are internal routed however you can run an external through the top of the top tube and exit it above the shock just like the earlier Stumpjumpers
All ours except one use the quick release guide and that uses the non quick release dropper guide, don't have a problem with any of them
Hope this helps
Posted : 11/05/2016 2:07 pm
You can buy stick-on cable guides.
Posted : 11/05/2016 2:11 pm
I think the issue is wenanwhere is using a reverb (which he should have clarified! 😉 ) so the hose is more flexible than the specialized dropper, meaning it bends and bows out rather than slide through the cable guide.
Posted : 11/05/2016 2:14 pm
Yes it doesn't slide through the cable guide and has become a bit bent as a result
Posted : 11/05/2016 9:14 pm
Different bike but I've used a cable tie on the qr to create a loose enough loop for the cable to move through
Posted : 11/05/2016 9:17 pm
