Show me your 700c w...
[Closed] Show me your 700c wheeled, disc brake equipped, hub geared bikes with a rack.
12 Users
Current rack has had a bit of an incident so I need a new 'un.
Genesis Day01 Alfine 11 with Avid BB7s.
What you got on yours?
Posted : 20/12/2012 9:09 pm
You need pics to choose a new rack?
Seriously?
Posted : 20/12/2012 9:13 pm
Simply because, having looked over previous threads, there's a lot of talk about Tubus and Tortec racks which I know for a fact won't fit my frame.
So I actually want to see one physically attached to a frame before buying.
Posted : 20/12/2012 9:17 pm
It can be a real bastard getting a rack to fit on some disk-equipped frames. The Super Tourist DX seems to avoid most problems though. I tried a Tubus - with disk adapter - on my VN Amazon and it just wouldn't fit.
Posted : 20/12/2012 9:19 pm
Tortec won't fit? How not?
Try Topeak or Blackburn.
Do you have an lbs to ask for advice?
Posted : 20/12/2012 9:20 pm
Aye, LBS advice was a Super Tourist DX, but I'd like to look at some other options.
Posted : 20/12/2012 9:26 pm
The Blackburn disk-specific one fits much like a Super Tourist too.
Posted : 20/12/2012 9:27 pm
topeak do not that pretty disc friendly racks. although oddly the non-disc version is the only one that fits my 456. The disc version is on my v braked hybrid.
700c CHECK
Rohloff CHECK
BB7s CHECK
No rack but the pompetamine will take one.
Posted : 20/12/2012 9:28 pm
My pompetamine, rack, mudguards and panniers arrive tomorrow. I'll post some exciting pictures then... 8)
Posted : 20/12/2012 9:30 pm
Stoner - Member
700c CHECK
Rohloff CHECK
BB7s CHECK
Aye, but which one? 😆
sc-xc - Member
Which ones did you go for?
Posted : 20/12/2012 9:32 pm
Blackburn something or other - it was on special at on one
Posted : 20/12/2012 9:35 pm
I have a rack on my derailleur geared disc road bike, but I guess that's not relevant 😛
Posted : 20/12/2012 9:39 pm
You've got me thinking now. I bought [url= http://www.on-one.co.uk/i/q/RABLMTN1RPRACK-BLK/blackburn_mtn1_rear_pannier_rack___black ]this rack[/url] - it says it is the 'Original and best selling mountain rack for rear use'
Would a 'mountain' rack fit the Pompetamine? - this may be a stupid question, but I am new to racks.
I understand there is only one set of holes, and I intend to run SKS mudguards - so a bit of bodging will be required.
Posted : 20/12/2012 9:43 pm
I tried to fit SKS mudguards on my Genesis. Good luck 😆
Posted : 20/12/2012 9:44 pm
The problem is usually that the rack struts foul the disk caliper, but this is very frame specific. The Super Tourist ( and the disk-specific Blackburn rack) have a stand-off arrangement to prevent this happening. FWIW, I managed to fit a standard Blackburn rack to an Inbred just by using a couple of thin washers as spacers.
Posted : 20/12/2012 9:46 pm
Will the 700cc wheels be a problem? Are racks different heights?
They can be. Trying to fit a 26" rack over SKS mudguards might cause an issue with tyre clearance. If it's a Blackburn (or a copy thereof) you might be OK.
Posted : 20/12/2012 9:48 pm
Ah well. It was only £15. I guess that's me shopping tomorrow then. 😐
Posted : 20/12/2012 9:49 pm
If you are going to be carrying a decent load then it's worth getting a good rack. If you are going for panniers, then one that has the additional rear struts is also a good idea.
Posted : 20/12/2012 9:51 pm
The one I ordered:
The one you recommend:
[img] ?w=350&h=350&a=7[/img]
Is it the second horizontal bar I need? EDIT - just seen the additional vertical bar as well.
Posted : 20/12/2012 9:52 pm
Yeah, Druidh that's what I'm after.
Don't have any photos of my bike, but [i]I think[/i] this is what it looks like.
Actually, no it's not. Not at all.
Posted : 20/12/2012 9:54 pm
No hub, does that matter?
[url= http://farm8.staticflickr.com/7106/7035837191_3ac99930a1_o.jp g" target="_blank">http://farm8.staticflickr.com/7106/7035837191_3ac99930a1_o.jp g"/> [/img][/url]
Tortec Apex, the whole side slides out as wide as you want it. But have to attach my ortliebs to the top bar to avoid heel chaffing.
Posted : 20/12/2012 10:31 pm
You were saying something about sks guards not fitting alfine disk day ones ? Even got 35mm schwalbe marathons on there the now.
Stainless steel madison tubus logo copy on there too....
My road rat same guards same rack.
Posted : 20/12/2012 10:56 pm
I can confirm a pompetamine with alfine 11, mudguards, avid elixirs and and a blackburn ex1 rack work fine (so sc-xc yours looks ok) - can take photos tomorrow if you need
Edit soz didn't realise sc-xc yours is a different model, it looks the same but confident prediction retracted!
Posted : 20/12/2012 11:11 pm
Brill, cheers. Getting excited now....!
Posted : 20/12/2012 11:13 pm
Looks a useful bike that Kaffenback.
Posted : 20/12/2012 11:51 pm
What tyres are you sporting Stoner?
Cheers.
Posted : 21/12/2012 11:23 pm
@trailrat can you post some close ups of your rack fitting around the caliper/braze ons please? Ta.
Posted : 21/12/2012 11:58 pm
35c small block 8s.
Posted : 22/12/2012 12:04 am
Posted : 22/12/2012 12:35 am
Ta. Is that a long set screw and a few nuts as spacers? Doesn't look like you needed any on the drive side?
Posted : 22/12/2012 8:29 am
For aesthetics you do of if your running a fat tire.
I always equalise them to center the rack anyway cause im anal.
Its a long screw and some vbrake spacers ( all a disk compatible rack is is a rack with a spacer built in)
Posted : 22/12/2012 8:57 am
Sorry everyone, this has turned into a 'fitting racks to Day One's thread 🙂
You said you could get 35's on yours.... They must be a bit undersized? I couldn't get anything bigger than 25's on mine (Pasela's and Marathon's) with SKS narrow guards. The top of the fork bridge being the main offender so I can't see a way around it.
Posted : 22/12/2012 11:30 am
TR have you had much weight on it? Doesn't look the strongest to me.
Posted : 22/12/2012 11:39 am
CA, do you mean a long m4 set screw cantilevered like it is? I don't likely the look of it either but mine won't carry any real load, just local one pannier stuff. Could always use Grade 8.8?
Posted : 22/12/2012 11:51 am
Ferkin glitchy shitty slow site
Toured shetland , orrkney and back to scotland no bother
If it comes loose its ****ed. But good maintainance 🙂
Mines does the weekly shop on the road rat snd i even took a months worth of off shore gear home from work on it after a short notice check in .
Posted : 22/12/2012 11:56 am
Infact. Jayne did 5 months touring new zealand on and off road with it fully loaded with camping gear with the same rack on a kona dew disk.
I had cantis
Neither had any issue with the racks
Posted : 22/12/2012 11:58 am
Fair enoguh trail rat.
boblo - I had one of these racks and a M5 bolt broke at the bottom, due to stress/flex I presume, in Switzerland. Bodged it and finished OK, and still use it on my commuter, but did not inspore confidence.
Posted : 22/12/2012 12:00 pm
If a rack bolt works loose your boned . Itll see high dynamic loading.
Id be looking towards that for issues ..... Or cheap stainless bolts supplied with most racks - the shiny silver ones !! I prefer nice hi tensile surface rusty bolts anyday.
Never had an issue with a single rack ever and as far as i know none of my customers did either Also try and stick a nyloc on the back if possible to prevent it coming loose but with modern deraileurs this isnt always possible.
Posted : 22/12/2012 12:09 pm
Could be the bolts right enough.
The end is still stuck in my 29er frame 😀
Posted : 22/12/2012 12:14 pm
Posted : 22/12/2012 12:15 pm
I always use grade 8.8 for the bottom fixings with a bit of thread lock. That kills both potential problems at source. I have a Tortec Ultralite rack for my Day One, just haven't fitted it yet as I've been using an old MTB to commute with and that's already fully sorted.
Posted : 22/12/2012 12:44 pm
