Show me your 1 X 10...
[Closed] Show me your 1 X 10 setups!
13 Users
pretty please! looking for some inspiration as ive got all the bits and am about to tackle setting it up this weekend!
gone for a xcx ST and hope 32t! looking forward to using it and saving a bit of weight and less hassle cleaning!
Posted : 21/06/2012 7:54 am
Posted : 21/06/2012 7:58 am
[IMG] [/img]
[IMG] [/img]
Posted : 21/06/2012 8:00 am
1x9 but whats one ring....
X9 Mech, 12-34, 32t front, Superstar Plasma guide.
Posted : 21/06/2012 8:03 am
OW How did you get on with the seat positioning? (was you wasnt it?)
Yeah it was, I have just seen your post on the saddle setting thread.
Glad it worked out for you..
Posted : 21/06/2012 8:29 am
hi tinsy - yep advice of all in that thread helped, i probably would have just left it and been uncomfortable had i not started that thread!
it seems pretty much perfect now, just took a little time to get right, worth it in the end though! so thanks again 8)
nice pics above - very nice! looks so simple, effective, clean lines etc!
btw anyone, when it says you have to put the ring on the middle ring to get the best chainline im guessing that means on the crank arms where the tabs are, you position and tighten up the ring onto where effectively the 2nd ring would sit on your cranks on a 3x10? never taken the cranks apart so not to familiar with it?
Posted : 21/06/2012 8:49 am
 will
1x9 but you get the idea.
11-32 cassette
36T ring
Superstar XCR Chainguide
Ultegra shortcage mech
Posted : 21/06/2012 9:04 am
12-36 sram pg7 or something cassette
30t Extralite front chainring
Straitline serrated bash
Blackspire stinger
(Unpictured) N-Gear jumpstop - chain would occasionally drop under repeated compressions
Posted : 21/06/2012 9:12 am
Not something Ive looked to far into but i own a anthem x with a press fit bottom bracket an no tabs for any form of chain device how do you get around this to keep the chain on, also comming from 3x10 what sort of gearing do you lose top an bottom? i generally dont use my granny but do use the big ring on the road down hill etc also what sort of weight savings are gained? i understand you loose your shifter,cables,mech an two rings but them chain devices an bash guards dont look over light? Cheers for any light shed
Posted : 21/06/2012 11:15 am
Only a l'il picture, as I can't get onto Flickr for the proper one!
36t custom ti chainring (stupid 88mm BCD on M985 cranks), XTR mech and 11-36 cassette, Superstar XCR chainguide with homemade seat tube mount.
I really like it!
[img] http://t2.gstatic.com/images?q=tbn:ANd9GcREc2-Al-vx1v98cjTimyqf7QuHS3fdVBACf2-EwKh4zh-Klen0 [/img]
Posted : 21/06/2012 11:20 am
Would this work....
One of these on the inside
http://www.chainreactioncycles.com/Models.aspx?ModelID=17283
one of these on the outside
http://www.chainreactioncycles.com/Models.aspx?ModelID=5357
One of these in the middle
http://www.chainreactioncycles.com/Models.aspx?ModelID=80578
Thanks in advance
jono84 - Member
Pivot make an adaptor plate which clamps right onto the bottom bracket shell. Looks like a good solution for these stupid designs...for the sake of adding 3 little tabs..
[url= http://www.pinkbike.com/news/Pinkbike-Product-Picks-december-17-2011.html ]Click Click[/url]
I use quite an easy combo of rings, a 12-36 at the back and a 32t at the front. This means I can winch up the hills, and frankly, pedalling DOWNhill is not something I'm into... 😀
Mind you, I don't normally find that I spin out..
Posted : 21/06/2012 11:43 am
I went belt + braces with a full chainguide (straitline silentguide), but then my reasoning was ground clerance rather than any weight loss or reliability issues, I just wanted an extra inch clearance under the BB.
Posted : 21/06/2012 11:52 am
 will
I thought i'd spin out, but with a 36T up front I've been ok so far.
Posted : 21/06/2012 12:05 pm
njee20 - Member
I really like it!
njee looks like how my setup (although ive paid a stupid amount for an e13xcx st one 🙁 ) ....do you ever drop the chain with that guide? are you running a clutch mech too? i know you race etc so a bit more flowy terrain, but most courses certainly are still gnarly enough to cause it drop chain id guess?
cant wait now!
shop tells me i should lose about .5lbs!
Posted : 21/06/2012 12:42 pm
 mboy
Another MRP Lopes user here...
Well, I would be if I hadn't cracked the upper guide yesterday afternoon whilst cleaning it! Note to anyone else out there... Superstar make chain devices with monkey metal, but tough plastic. MRP make VERY strong back plates, but on the Lopes SL certainly, the guides are made of pretty soft materials. Went straight onto CRC to order a replacement in time for the weekend, which is at least only £15, but alas, none in stock for weeks! 🙁
Fortunately got someone gonna lend me a Top only guide for Mayhem... Or also contemplating just putting a granny ring on also, with no shifter or mech, and changing manually in the mud! The time I take to change manually will probably be less than the time many people spend digging mud of their front mechs...
Oh, and 32T ring, 11-36 Cassette. I ride it on the Malverns though once in a while. If it was for flatter terrain, I'd fit a 34 or a 36. But as it is I'd rather the slightly lower gears than the slightly higher ones, if I'm spinning out 32/11, then offroad i'll go faster by pumping anyway, and on road... Well I'm not bothered about that, I've got a road bike if I wanna go silly fast down hills!
Posted : 21/06/2012 12:49 pm
Never. It's my only MTB too, so it's done plenty of 'normal' and trail centre riding away from race courses, Afan, Dalby, Haldon etc as well as regular Surrey Hills riding and I've yet to drop the chain.
Posted : 21/06/2012 1:04 pm
great stuff! cheers njee! sounds like itll be fine then given im running a clutch mech! really cant wait to use it now, just have a feeling it will be hard to line up? cant just picture it catching on the hi/low gears at both ends!
i take it i dont need to remove any bb spacers now as im using a seat tube version? ideally should all fall into place as effectively my middle ring is still in the same place as before, and they chain guide i guess will run the same height and same way the cage on my front mech did? thus hopefully meaning it should be clear of rubbing?
Posted : 21/06/2012 1:08 pm
Will,
Is the Ultegra mech OK with the 32T cassette sprocket?
PaulD
Posted : 21/06/2012 1:25 pm
 will
Yeah, certainly is Paul. Not going to be as smooth on the 32 as a Mtb mech, but it works perfectly, and looks alot better!
Posted : 21/06/2012 2:10 pm
