Should I get new ro...
Should I get new road bike tyres?
13 Users
I've got Schwalbe Pro One in 28c, not especially worn but quite gummed up with sealant I can't remove, makes them hard to fit and remove, and they have cuts so they weep.  I can get Vittoria Rubino Pro IV in 32c for £30 each. Worth it?  I think the extra size would be quite nice?
Posted : 02/11/2025 9:32 pm
I'm finding wider tyres better in general so I'd go for it.
Posted : 02/11/2025 9:38 pm
 Aidy
IME Rubino Pros are a *lot* more sketchy than Pro Ones. I'd avoid them.
Posted : 02/11/2025 9:47 pm
I think the opposite! I find Rubinos to be far more durable and with better wet grip.
Posted : 02/11/2025 10:20 pm
Wider is better, especially if running tubeless as the lower pressure you can run the more chance you have of the sealant working. No idea on those specific models though, I use 35mm Conti GP5000ASTR's over winter
Posted : 03/11/2025 7:14 am
Assuming your frame/mudguards have the clearance, wider is definitely more comfortable and less sketchy in the wet.
Posted : 03/11/2025 9:18 am
Yes get new tyres - once the tubeless setup goes messy and high maintenance it's time to start again. And if wider will fit, that's your moment to size up.
(also - are you lot disagreeing about the same compound Rubinos?)
Posted : 03/11/2025 9:32 am
I doubt a 30c Rubino will be any larger than a 28 pro one.
In my experience Pro ones inflate bigger than stated size, while Vittorias (Rubinos and Corsa paves) are more true to size.
Posted : 03/11/2025 9:33 am
Rubinos are decent for the money. I've Zaffiro Pro's in 25c on two bikes and they behave very well on crappy gritty country lanes. They haven't cut up. PS - my bikes take 25c max. The Vittoria sizing is pretty spot on.
Posted : 03/11/2025 9:43 am
I'd personally get another set of Pro Ones, great tyre.  Wider if you feel like it, but as said earlier they do inflate widely anyway.
Posted : 03/11/2025 1:21 pm
 Jamz
Yes, I would try the Vittorias. Rubinos are great for a winter tyre. The Corsa N.Ext is also very good. Slightly faster and slightly more expensive, probably worth a tenner extra to be honest.
Posted : 03/11/2025 1:26 pm
Basically I want nice tyres but I don't want to spend much more than £30.  If anyone knows any other bargains, I'd appreciate a tip 🙂
Posted : 03/11/2025 1:53 pm
My bike came with 28c Rubinos, they seem fine to me. Part of my usual road route is on a cycle path which is currently covered in wet leaves and I haven't died yet.
Posted : 03/11/2025 8:18 pm
At 28mm just get some tubes. Is tubeless really any better at that size, especially with the extra cost and general faff?
Posted : 03/11/2025 9:27 pm
The question is if it's worth going to a larger size.  But I bought some now anyway.
Posted : 03/11/2025 9:35 pm
