What's the shortest dropper post out there? My daughter has a xs Trance, there's about 16cm max insertion in to the seat tube and she has her saddle at about 16cm again. There was a thread on here a few months ago about someone with a similar issue but i can't find it.
http://singletrackmag.com/forum/topic/small-frame-seat-post-reverb-quandary
Got a KS supernatural. Definately didn't need more than 75mm of drop. Only downside is it has got gunked up after only 3 (albeit peak grit and mud) rides so needs to be kept clean.
Thanks nickjb but not that one. But the idea of cutting a GD (or similar) hadn't occured to me.
evh22 thats the one. I thought the KS were 380ish which is about 60mm to much or are you running it half mast if you ctch my drift?
edit: Just noticed in the thread someone said you can get a 300mm KS i'm guessing thats what you went for?
Yes: 7.5cm drop, then collar and the rest in the frame. £125 on hibike. Is that enough drop for her?
When you look: Dropzone = 2cm layback. Supernatural = no layback
They never tell you these things!
Thanks evh22. Should be plenty for her, her current seat post is only 9-10 inch.
evh - do the KS Supernat come with this [url= http://kssuspension.com/products/accessories/supernatural-mud-boot/ ]mud guard?[/url]?
Yes, but its no match for the peak grime. 😥
