Shortening hoses wi...
[Closed] Shortening hoses without bleeding
9 Users
On formula cura brakes. Or should I just resign myself to this godforsaken task?
Brand new, I haven't got a bleed kit and I bet they need doing from both ends. It was such a pleasure bleeding hope brakes the other day after the faff with shimano.
Posted : 16/10/2017 3:39 pm
why would they?
Posted : 16/10/2017 4:15 pm
if brake are all ok and it just shorting the hose (New brakes?)
Take the pads out, squeeze the brakes so the pistons come out a bit,
(not to far thou)
remove hose at lever, cut/shorten, fit olive/insert etc.
Refit hose
Slowly push pistons back in(any bit of air should be pushed back to the lever)
Fit pads etc test and go ride.
Posted : 16/10/2017 5:40 pm
No need to cut the hoses to shorten them, just tie them in a bow.
Posted : 16/10/2017 5:42 pm
Don't know about Formula brakes, but I've shortened Avid/SRAM brakes plus Reverb hoses without the need to bleed. Careful cut, keep ends up and don't drip, don't press lever in, refit hose. Job done usually.
Posted : 16/10/2017 6:50 pm
I'm patenting some elastic hoses that stretch/shrink to fit.
Posted : 16/10/2017 6:53 pm
What MTB Rob said.
Posted : 16/10/2017 10:18 pm
(not to far thou)
Refit hose
Good hack, I've used this before. 😀
Posted : 17/10/2017 4:59 am
Edited, Double post.
Posted : 17/10/2017 5:16 am
I completely forgot I'd posted this - thank you, men.
why would they?
Are there not brakes that require syringing from the caliper out as well as from the lever in?
Posted : 21/10/2017 8:50 am
Depends on the shape of the caliper.
Posted : 21/10/2017 1:35 pm
