Shortening brake ho...
[Closed] Shortening brake hose
5 Users
I have excess hose on my front M4 brake, Ive just decided now after about 3 years to shorten it to make it look a bit tidier.
What I'd like to know is if I do will I need a new brass olive or can I use the original one ,or is it just not worth the time and effort ?
Posted : 14/12/2009 9:13 pm
you can use the old one
don't take it off - just push it down & cut
Posted : 14/12/2009 9:14 pm
Take a look at this:
http://www.gravity-slaves.co.uk/?a=226
All carried out on an Mono M4 front brake.
Posted : 14/12/2009 9:16 pm
if there the same as mono mini's they are a piece of pee.
the olive is a split design, just split it a little then pull it back.
next get a small blade screw driver and try to pry the hose away from the fitting, it is just a push fit but nice and tight.
cut hose, refit, bleed, bingo.
Posted : 14/12/2009 9:17 pm
Cheers Guys
Posted : 14/12/2009 9:22 pm
Would it be as easy as that with braided hoses?
Posted : 14/12/2009 9:37 pm
not sure about braided, guess they are fitted the same, take the back nut off and have a look if they have the split olive.
Posted : 15/12/2009 9:37 am
