I need to shorten my reverb hose. I've watched the SRAM video online and from what I've seen, it's not going to be an arse-ache with fluid all over the place or is that just the video being optimistic and it will piss fluid all over my kitchen floor?
The process seems to be:
Unscrew threaded barb
Cut
Rescrew
Cuppa
That all there is to it?
If you follow the video its pretty straightforward. Just remember the bit about winding in or out (I can't remember which it is) the speed adjuster before you make the cut.
Yeah its simple enough. Barb isnt threaded just ribbed (not sure if that's what you call it) so its just a case of pushing the hose over it. Its just Make sure you get the hose properly seated on the barb when you reterminate or it can let air in and lock the system. You may need to bleed the system if any air gets in. Should only be the odd drop of fluid coming out when you cut/reterminate.
Actually, the barb on Mrs L's reverb is threaded. I never checked mine before shoving it in
It is simple but you'll need to bleed it as air will get into hose.
Was suprised what little mess there was.
I've done it 3 times now and never had to bleed, really simple to do.
Cut
Rescrew
Cuppa
Yep, that's all I had to do. I shortened mine recently - even bought a bleed kit in advance expecting to make a mess of it and have to re-bleed... but it was dead easy and works perfectly..
I cut mine with a craft knife - no mess, and no need to bleed. As it was evening I had a beer after.
Living room it is then.
thread resurrection 🙂
new (warranty replacement one) on it's way to me so will need to shroten tomorrow. Does anyone know if the new ones are threaded barbs ?
Thanks
edit, updated the wrong darned post 😳
[url= http://singletrackmag.com/forum/topic/reverb-hose-shortening-query ]hey ho ![/url]
I'm not sure i can remember this as i don't think it was in the vid but make sure you screw in the hose at the seat clamp BEFORE sorting your cable routing as if not you'll have to do re route. Sounds stupid but that's what i did.
Was exactly that easy for me, no bleed required.
Don't be a numpty and press the button in between taking the hose off and putting it back on though.
Mine was threaded, yes.
great, ta, sounds like it should be threaded so the lever end barb should unscrew rather than need cut out like on the vids. I carefully measured lenth of old hose and took pics of the routing, so fingers crossed 🙂
Just done one which required little effort and no bleeding which isn't that much of a chore anyway.
