Short travel droppe...
[Closed] Short travel droppers
6 Users
Think I'd like to try a dropper on my gravel (i.e. adventure/all-road/insert-your-term-here) bike.
Unfortunately even my 100mm travel Gravity Dropper is too long though...
Are there any 27.2mm, non-bar-operated, <100mm travel dropper options aside from the KS ETEN?
You'd think there's not a market for such a thing or summit!
Posted : 19/02/2019 1:35 pm
XLC, Pro, KS Lev 272... quite a few options: https://r2-bike.com/Seatpost-height-adjustable__272-mm_3
Posted : 19/02/2019 1:55 pm
brand x do a 85mm CX dropper
Posted : 19/02/2019 1:57 pm
Can you just get a shorter inner post for the GravityDropper?
Posted : 19/02/2019 10:52 pm
I used a ETEN to prove the concept, but I’m going to buy a PNW Pine now.
Posted : 19/02/2019 11:12 pm
XLC, Pro, KS Lev 272… quite a few options:> https://r2-bike.com/Seatpost-height-adjustable__272-mm_3
Thanks for the pointers 🙂 The really tricky thing is getting one without a bar remote, as I'll switch the dropper for a rigid post when riding primarily on roads, and don't want to faff rerouting cables every couple of weeks.
That said, there's an XLC post there that I didn't know about that could work.
May be, hadn't thought of that. Although the GD is a spare for my MTB so I'd rather not reduce the drop to be honest. Where do you get GD spares in the UK anyway?
Posted : 20/02/2019 8:39 am
The really tricky thing is getting one without a bar remote, as I’ll switch the dropper for a rigid post when riding primarily on roads
1) why bother
2) get an external routed one and some cable ties will take minutes to mount and seconds to shop off if you really feel the need to keep swapping posts.
If I go out on the gravel bike and plan a road route I'll inevitably come across a bridleway or path I fancy exploring so always having the option to drop the post is a winner for me.
Posted : 20/02/2019 8:48 am
I would just try contacting the GD people in the US and ask them. I've always found them fairly helpful.
Posted : 20/02/2019 9:02 am
Just a note on this in case it helps anyone for droppers in general, I realised that I can fit a 100mm travel ETEN in there.
Two things:
I found out that the collar-rail length of the KS ETEN is almost 2cm shorter than the Gravity Dropper for the same 100mm drop.
I noticed that, measured from rails to the top of the seat, i.e. the stack height, my Charge Knife is just under 4cm and my Change Spoon is 5cm.
So the GD with a Spoon is 3cm longer than an ETEN with a Knife, and I've got space for the latter.
Posted : 22/02/2019 8:26 am
I've got a KS Lev on mine. Can't think of any reason i'd want to swap it back out for a rigid.
Posted : 22/02/2019 9:02 am
