Short rigid fork (&...
[Closed] Short rigid fork (<400mm) with 29er tyre clearance?
6 Users
Anyone know of a short, gravel-bike length fork with tyre clearance for a 29er wheel? (that don't cost a fortune...)
Soma Wolverine forks are about the only thing I can find: (400mm a-c, clear a 2.1" 29er tyre). And pretty hard to get hold of.
EDIT: I posted some Thorn one's yesterday, but they're a touch too long.
Posted : 21/09/2019 12:57 pm
If you don't need a tapered steerer, then I do know Surly CrossCheck forks easily clear 2" tyres, so I would assume Straggler forks would do the same with discs. Otherwise, custom? Shorten some On One rigid forks?
Posted : 21/09/2019 1:05 pm
Ah, great, thanks, I just found a pic with a 2.2" Ikon in a Straggler fork, so may be that's another option.
Posted : 21/09/2019 1:20 pm
I didn’t think 29in went into 400mm forks. If it did I would have gone shorter on the Bootzipper 29 so people fitting suspension would have an even worse ride.
Posted : 21/09/2019 2:07 pm
3t luteus ii will unofficially take a 2.1 apparently..... It has huge clearance.
400 a to c, 50mm rake
Posted : 21/09/2019 2:12 pm
I'm all in favour of that 🙂
The largest official clearance short fork I've found is this:
https://bikepacking.com/news/bearclaw-carbon-gravel-fork/
405mm a-c with clearance for a low-tread 29x2.6
Posted : 21/09/2019 2:25 pm
(in fact, I guess if you gave a fork a big enough offset you could make it as short as you wanted...)
Posted : 21/09/2019 2:42 pm
 Bez
Surly Disc Trucker fork is 390mm, I’ve had 2.0” 29er tyres in it with space for a bit more.
Posted : 21/09/2019 3:15 pm
Surly fff (fit for fatties) long hail trucker. What a great bike
Posted : 21/09/2019 8:16 pm
Bloody hell, these would have done it for £20!
https://www.merlincycles.com/merlin-gravel-forks-161479.html
Posted : 21/09/2019 9:31 pm
