Shock mounting hard...
[Closed] Shock mounting hardware question
2 Users
What varies on different bikes and shocks?
The distance between the eyes on the frame
The diameter of the hole in the shock
What else?
My 5 has the two aluminium top hats on the rear mount, the Patriot has a large hollow axle instead. Are the two interchangeable?
Posted : 02/10/2014 9:39 am
 LoCo
Width of shock in frame, (width of bush)
diameter of mounting bolt (hole in spacers/mounts)
Eye to eye of shock,
Stroke of shock
diameter of shock eyelet but 1/2" X 1/2" (12.7mm X 12.7mm) on Rockshox & fox. (eyelet bush/du bush diameter)
Also:
All compatible, for 1/2" x 1/2" apart from fox low friction as spacers different width due to shoulder on eyelet bush (cream parts)
Posted : 02/10/2014 11:20 am
Those bushes worked perfectly on the 5, not on the Patriot though. I'll have to come up and see you tomorrow morning Loco If you have anything.
Manitou Swinger x4
Frame width is 22mm
Diameter of stainless steel 'tube' is 12mm
Internal diameter of shock eye is 14mm
Posted : 02/10/2014 11:50 am
 LoCo
ah! mantiou 2011 and earlier is 12mm didn't know you had one of those on the Patriot
Posted : 02/10/2014 11:56 am
Do you have one of those in stock?
Posted : 02/10/2014 1:18 pm
 LoCo
Yep
Posted : 02/10/2014 1:27 pm
Ok tomorrow AM then?
Posted : 02/10/2014 2:25 pm
 LoCo
Yep Peter is in until 2pm, I'm in Cornwall, will put a bag to one side for you.
Posted : 02/10/2014 2:39 pm
Ta. Both ends of shock?
Posted : 02/10/2014 2:46 pm
 LoCo
eyelet bushes , yes spacer no as pretty rare we're asked for them now, try the bushes first and can always order spacers if needed.
Posted : 02/10/2014 4:04 pm
Hmm, may not be enough. The tube bit is visibly worn, plus I've managed to lose one of the washers.
Posted : 02/10/2014 4:23 pm
PS Loco, sorry - I found a complete hardware set at Rush in Bridgend so picked that up instead.
Took the forks to Cwmcarn on Saturday, after only one ride they were plusher than ever - thanks for all your help and patience!
Posted : 06/10/2014 1:48 pm
