Shock mounting bolt...
[Closed] Shock mounting bolt fouling on bushing
4 Users
I'm having some trouble removing the upper mount bolt on a rear shock.
The shock mount bolts look like this:
So on one side there's a (female) threaded sleeve which goes through the shock bushing, and on the other side a (male) bolt secures it.
The lower bolt undid OK: I backed the bolt out while securing the sleeve with an allen key, and then slid the sleeve out through the bushings to release the shock.  The sleeve took a little encouragement to come out, but nothing too excessive.
The upper bolt is a problem.  I can back out the bolt just fine, and the sleeve then slides through the frame mount so far as the shock bushing, but stops there.  I've tried giving it a little encouragement with a punch and mallet to no avail -- its almost as if the sleeve end has flared out slightly and is now fouling on the inside of the bushing.
Any ideas on how to solve this problem?
Posted : 17/07/2018 2:12 pm
Put the bolt back in a couple of turns and hit it harder.
Posted : 17/07/2018 2:20 pm
yes. And if that's not enough: piece of threaded bar.
Posted : 17/07/2018 4:08 pm
More hammer required, eh?
Thanks folks, I will try giving it a bit more of a bash and see if it can be forced out!
Posted : 17/07/2018 9:09 pm
have you tried putting it through the opposite way?
Posted : 18/07/2018 9:53 am
