Shock hardware - ho...
[Closed] Shock hardware - how tight
3 Users
Just had some custom shock hardware made, how tight should they be through the DU bush? Hand pushable or vice push? I measured them and the OD is bang on .5". Had to press fit them and the shock needs quite a bit of pressure to swivel around the pin.
So do I a: leave it and let it wear in or b: whip it out and take a smidge off the OD?
Surely the tightness is affecting the suspension or not really...
Posted : 14/01/2014 5:40 pm
 LoCo
Interferance fit, press fit if have very strong hands or vice for gentle fit, rotation shouldn't be too sticky, but depends on bushing & spacer materials
Posted : 14/01/2014 5:43 pm
Should be able to push in by hand in my experience. However... the last time I put a DU bush into the Mrs' Vivid I had to press in the hardwear afterwards, couldn't see a reason for the change so just put in down to a tolerance build up
EDIT: ignore me and just listen to the guy that does it for a living
Posted : 14/01/2014 5:44 pm
Cheers loco, STD issue Fox metal du and a one piece alu rod.
Ill try to whip it out without knackering it.. its tight, had to G clamp press it in.
Posted : 14/01/2014 5:49 pm
 LoCo
Std. fox du are quite tight as standard generally, we replace them with polymer ones with full services, slightly slacker and less static friction.
Posted : 14/01/2014 5:52 pm
Shall I just forget about it and ride my bike.. Itll take longer to wear out...
Posted : 14/01/2014 5:53 pm
 LoCo
as long as it's not so tight the eyelet bush is rotating in the shock eyelet. The eyelet/du bush will just wear anyway.
Posted : 14/01/2014 5:56 pm
Dont think it is, it wasnt that tight it was trying to push the bush out when I fitted it.
Posted : 14/01/2014 5:57 pm
 LoCo
'should' be fine then.
Posted : 14/01/2014 6:00 pm
Cheers.
Ill have a ponder.
Posted : 14/01/2014 6:04 pm
