Shock extends back ...
[Closed] Shock extends back even with air let out..normal?
5 Users
Hi all, my mrs has a fox float shock that she hasn't used for some time. If I let the air out of it and try to push down (not fixed to the bike) its really really hard to push it down through all its travel then when I let go it just extends back up again. Ive got a rockshox monarch and that doesn't do it, is this normal with these shocks or is it buggered? It says propedal on the side (sorry don't know much about suspension).
Posted : 01/09/2016 10:01 am
There's still air in it after you've "let the air out". It's just at the same pressure as the air on the outside of the shock.
When you push down, you compress the air, so when you take your weight off the bike it extends the shock again to reduce the air pressure inside.
Although it might need a service/relube if it's not been used for ages.
Posted : 01/09/2016 10:04 am
Open the valve (push down on the pin in the schrader valve) while you are compressing the shock. That will get all the air out.
Posted : 01/09/2016 10:06 am
Even a coil shock with the spring removed still extends itself, so absolutely fine
Posted : 01/09/2016 10:26 am
The damper circuit is still pressurised so it will want to extend. If its difficult to compress it may be you have the damping set in locked/semi-locked mode.
Or of course it could be buggered, difficult to tell over the internet 😀
Posted : 01/09/2016 10:33 am
