Shock bushings or m...
[Closed] Shock bushings or mount kit?
7 Users
 gt56
Hi all, I hope someone can help..
my mondraker foxy has developed some rear end play when I hold it by the frame and pull up. I have tightened the bolts so assume it is something to do with the shock mounting.
The question is.. can I get away with replacing the bushings or will I need to buy two new mount kits? Any advice much appreciated.
Posted : 26/02/2013 2:23 pm
You should normally just have to replace the bushings, you will need a tool to do this though.
Are you sure the play is in the shock and not your frame pivot bearings?
Posted : 26/02/2013 2:24 pm
 LoCo
Eyelet/Du bushes first, then spacers (top hat or pins) if they're worn.
Check all the bolts and bearings in the rear end 😉
Posted : 26/02/2013 2:26 pm
 gt56
Great, thanks for your help. Steve, To be honest I am guessing with regards to the play. Ids there any easy way to check where it is coming from?
LoCo, how do I know what type of bushes to get?!! TFtuned say my shock (ario RL) and frame = 12.7mm bushings, will these fit? What are top hats? Help?!
Posted : 26/02/2013 2:40 pm
This [url= http://www.tftunedshox.com/info/mount_kits_bushings.aspx ]page[/url] shows a picture of the top hats and bushings. You need a tool to remove the bushing although I have done this using a pair of sockets and a vice. One socket the same or slightly smaller that the bushing to push it out and another larger socket to push it into and stop the vice holding it in place. With the right tools its a pretty straightforward job.
Posted : 26/02/2013 3:07 pm
You can get bushing tools on ebay for about a tenner.
Posted : 26/02/2013 10:59 pm
IIRC the polymer bushings are supposed to be longer lasting then the metal ones.
Posted : 27/02/2013 5:43 am
In my experience of this, regardless which type of bush you fit it will eventually fail again. So I fitted one of TF tuned's heavy duty mount kits and have never had any issues again. Need to do this on my latest bike as well, a true fit and forget solution.
Posted : 27/02/2013 10:21 am
 gt56
Thanks again all. Got a tenner tool and 2 bushings from ebay.. fixed in today and all smooth again! Nice one
Posted : 02/03/2013 2:23 pm
