Shimano xtr m9000 r...
[Closed] Shimano xtr m9000 rear shifter and Saint m820 brake lever
1 Users
I've currently got an I spec ii xtr m9000 shifter which is connected directly to an m9000 xtr race brake lever. I'm changing to Saint levers which are I spec b and the shifter doesn't fit directly.
Is there any adapter to allow the xtr shifter to be used with the Saint lever?
Posted : 15/02/2019 7:15 pm
Turns out I found the solution and it's straightforward (once I eventually found it) but not cheap!
https://problemsolversbike.com/products/brakes/rematch_adapters
Just posting incase this helps someone else sometime.
Posted : 15/02/2019 9:36 pm
