Shimano XT Brake Ho...
[Closed] Shimano XT Brake Hose Length
7 Users
Just ordered some for my medium Solaris, Are the hoses generally ok out of the box or am I likely going to have to shorten them?
thanks
Posted : 27/11/2018 9:47 am
You will have to shorten - they're normally at least 20cm to long, worse on an HT.
Posted : 27/11/2018 9:58 am
damn it. Will that mean a bleed as well?
Posted : 27/11/2018 10:05 am
I didn't shorten them on my HT to allow for a drybag on the bars, this was after shortening my previous hoses to a really neat length that totally got in the way of mounting a drybag.
If you don't plan on bikepacking, yeah you'll want to shorten them, but you could pretend you do plan on it to excuse your overlength cables/hoses.
Posted : 27/11/2018 10:30 am
They're usually 1000 mm front and 1800 mm rear so unless you have a 200 mm travel tandem they'll need shortening
epicbleedsloutions method always works for me
Posted : 27/11/2018 11:00 am
No, shortening doesn't normally need a bleed. Should come with spare olives and plug doobry thingys.
Measure, pull out carefully (oo-er), cut, install. Ride 🙂
(Not necessarily in that exact order)
Posted : 27/11/2018 11:07 am
I'll go onto you tube later - but assume you chop from lever end?
Posted : 27/11/2018 12:16 pm
Yes as the caliper end is a crimped end and you can't do it yourself.
Posted : 27/11/2018 12:31 pm
I’ve shortened 2 sets of Shimano brakes (slx and Deore) and never had to bleed them after. Just be careful when cutting and keep the cut end higher than the caliper.
Posted : 27/11/2018 12:34 pm
