shimano wet lube an...
[Closed] shimano wet lube anygood for muddy winter offroad
12 Users
hi, as above, is the shimano wet lube any good for winter offroad riding, moorland/sandstone grit trails and woodland loam/mud
a bargain deal on amazon
Posted : 15/11/2016 11:48 am
Dunno, I use Chain-L which is awesome stuff!
Posted : 15/11/2016 12:39 pm
 Yak
I would want something less sticky for that otherwise you are into mucky black grinding paste territory. So something like purple extreme, viking juice etc.
Posted : 15/11/2016 12:44 pm
I think almost certainly not as it does not say it's PTFE free (stuff that kills that very environment we love to ride). I've been using Green Oil ( http://www.green-oil.net) on my Zesty and road bike for years now and all year round. It works very well.
Posted : 15/11/2016 12:49 pm
Cheers guys I tend to use the rock n roll blue, or a chain lube I found in my dads garage, excelllent stuff, but couldn't find the brand online and it's nearly done, my supplies ran low on rock n roll too
So Bought a few bottles of this shimano stuff for £2.20 each 100ml, can always use having cleaned the bike and stop it rusting before the Next ride whilst it sits idle
Posted : 15/11/2016 2:07 pm
It should be fine. Anything is going to wear your chain down in truly shitty weather, so I'd ignore the grinding paste comment and just make sure you clean the chain/sprockets/chainwheels after every ride and reapply lube.
Posted : 15/11/2016 3:03 pm
Got some a while back Because It Was Cheap
Sticky so it stays on and sticky so it attracts debris and converts the drivetrain into a conveyor belt of cack
Curiously effective on stanchions though
Posted : 15/11/2016 3:22 pm
 adsh
Smells strong so must be good
Posted : 15/11/2016 3:54 pm
Is Finishing Line cross country wet lube any better for this ?
Posted : 15/11/2016 3:55 pm
Use chain wax, much better than any wet lube.
Posted : 15/11/2016 5:22 pm
I rate purple extreme for all year use.
As said, clean chain, cassette and chain rings after every ride
Posted : 15/11/2016 5:39 pm
It's the stickiest, muckiest lube I've used and quickly turns drivetrains into black, dirty blobs - but on the upside, it keeps things running reasonably smooth.
The dry version is better though.
Posted : 15/11/2016 6:02 pm
Shimano lube stinks like old engine oil and attracts so much dirt it's unreal. Never again.
Posted : 15/11/2016 6:32 pm
