Shimano Ultegra Shi...
[Closed] Shimano Ultegra Shifters
3 Users
I have a problem with the Ultegra Right hand lever that operates the rear mech shifter. I have a lever currently sitting on bars without cables. The ratchet mechanism is in the wrong place , ie the cable carrier is not lined up with the access hole at the bottom of the lever (making sense?). How do I release the ratchet to move the mechanism around to line up so that I can rethread the cable through the lever?
Thanks
Richard
Posted : 01/12/2014 2:41 pm
It needs to be in the 'smallest' sprocket - ie press the black 'release' lever at least 9 times to shift down the block.
Posted : 01/12/2014 2:50 pm
I thought so, with no cable fitted will the mechanism still shift?
Thanks
Posted : 01/12/2014 2:55 pm
Yep, it'll still move with no cable attached. If you think when you downshift it's sprung anyway, the cable's not doing anything.
Posted : 01/12/2014 2:58 pm
Thanks will try again .
Posted : 01/12/2014 3:03 pm
If they have been sitting for a while the grease can get too sticky and stop the pawl from releasing.
A good spay with a thin lube or solvent can get it moving again.
Posted : 01/12/2014 3:08 pm
All good now thanks for the tips.
Posted : 01/12/2014 5:52 pm
