First time using shimano brake hardware, will possibly need to shorten hoses at some point. Do I need this specific tool? If so are there any (much) cheaper alternatives to look at?
I've never used that.
Normally you get a yellow split block that allows you to clamp on the outside of the hose while you tap the insert in with a hammer, having done a good straight cut with a sharp knife.
I may be missing some complexity of up to date brake systems but that's how I've always done it in the past!
I’ve got cable/hose cutters, just thinking about inserting the gubbins into the hose end.
https://www.bikeparts.co.uk/products/clarks-hydraulic-brake-hose-multi-tool?currency=GBP&variant=44646684819613&utm_medium=cpc&utm_source=google&utm_campaign=Google%20Shopping&stkn=a894e8283159&gad_source=1&gclid=EAIaIQobChMI5uyHyarVhQMVxZFQBh29bQlYEAQYAyABEgJt5fD_BwE I bought a cheaper copy off Ebay that works perfectly
Exactly what I do and haven't died yet. Mole grips for a firm grip on the yellow blocks while you tap in the insert with a BFH.
Thanks all, StuE that looks just the job, (I’ve also just seen a jagwire version) I’ll get one ordered. Ta
I don't even use that, just snips and push the insert against the bench.
If you aren't in a rush I've seen the ztto version recommended from AliExpress.
Or you can get a copy of that Clarks one for 82p
I have a basic hose cutter now as it is just cleaner, easier and was not that much to buy. Before I'd clamp in yellow blocks then use a fresh Stanley knife blade to cut with the yellow blocks acting as a guide. As above for barb insertion though one clamped in the blocks I tend to push the barb in my holding the blocks (or thing clamping them) and pushing the barb against a flat surface.
Cable cutters tend to crush the hose a little. Works but the cut is not as clean as a razor bladed tool or Stanley knife.
The Jagwire insert tool "thingy" is an absolute must. I bought one recently having borrowed a friends and its a tool that instantly made we query "why don't I already have one of these"!
A proper hose cutter is worth it too.
I've got one of these:
https://epicbleedsolutions.com/products/hydraulic-brake-hose-cutter
Wrestling with those yellow blocks is a horrible task especially if you are trying to get away without bleeding.
Cut the hose with a fresh, new stanley blade, gives you a perfect slice through and doesnt fray the fibres in the casing. The little yellow clamp blocks work great in a vice, or if you havent a vice then clamped in some vice grips.
Never use any type of cutter, tin snips or shears that use a 'scissor' style two bladed action - thats how you end up with a wonky cut (Note how a proper hose cutter such as the link aboe only uses a single blade).
The insert you can just push or tap in against any hard surface. Remember to put the olive on first!
This. I’ve never needed to use a specific tool.
Ditto. After cutting the hose dead square, i initially put the insert in then tap it home using a soft faced mallet.
I've a woodworking thing called a mitre trimmer i use to cut the hose, just basically because i already have it and dont see the point of buying something else. Does the job.
Outer sleeve/shroud first, then the olive 😉
I did buy one. It is good. I found one quite a bit cheaper overseas
The Jagwire cutter is excellent, a slicing action with a clean finish. The Jagwire tool for inserting, well inserts, is also excellent. There are other methods which can be used but if you’re trying to shorten a hose, replace a calliper or lever then these tools allow the minimum disturbance and often bleed free alterations. They are reasonably cheap, they work, they make life easier!
