Shimano ST-RS685 Hy...
[Closed] Shimano ST-RS685 Hydraulic Disc Brake STI's & BR-RS685 Disc Brakes spare pads
3 Users
 2002
I may be getting defy fitted with these brakes and I was just looking for a spare set of pads but I can not see any where that sells them and I wondered if they are pads fitted from an other calliper from the Shimano range.
Posted : 03/01/2015 9:45 pm
Choice of 4 types of pad according to the tech docs. Part numbers are...
Y8LW98020 Resin Pad (G02A) & Spring w/Split Pin
Y8JZ98020 Metal Pad (G03S) & Spring w/Split Pin
Y8LW98040 Resin Pad (J02A) w/Fin & Spring w/Split Pin
Y8LW98030 Metal Pad (J04C) w/Fin & Spring w/Split Pin
Madison don't appear to have any of them in stock until the beginning of March.
Edit - same pads as XT 785
Posted : 03/01/2015 9:51 pm
 2002
Thanks for the reply as I have never had Shimano brakes only Avid on all my MTBs. I always like to have a spare set of pads in case you have a problem.
Posted : 03/01/2015 9:57 pm
