Shimano SLX M666 Br...
[Closed] Shimano SLX M666 Brakes - Any issues with Floating Rotors - Which brand??
5 Users
has anyone had any issue running floating rotors with Shimano SLX M666 disc brakes?
Thinking either;
Clarks
Superstar
Aztec
Posted : 28/02/2013 1:21 pm
I'm running the cheaper/heavier Shimano floating rotors with my SLXs, no issues so far.
Posted : 28/02/2013 1:23 pm
Have got 4 pairs of Superstar floating rotors they work fine with 596s/Juicys/Elixirs. If you're going to have any problems it will be with the buttons that hold the rotor to the spider they may foul on part of the caliper.
I had a 180 rotor with a button that was very slightly higher than the others (we're talking sub-credit card thickness here) and it was catching on the lower mount of the caliper. A few scrapes with a flat file - just enough to take the paint off the offending part of the caliper - was all it needed.
Long term they've been fine. Smooth, silent, no rattles or corrosion they are at least as good as the RT76s I also have.
Posted : 28/02/2013 1:53 pm
Posted : 28/02/2013 9:11 pm
Hopes work fine, previous years the caliper mounting points were over build and required filing down. This one appears better with more clearance
Posted : 28/02/2013 9:15 pm
May I ask why? They add nothing and bring problems. Not even particularily light because of the extra complexity.
Posted : 28/02/2013 9:17 pm
My Hope ones have outlasted any others in terms of staying straight. They also look nice. That was my reasons, a nice set of Hope Rotors colour matched to some hope hubs for the extra bling 🙂
Posted : 28/02/2013 9:23 pm
@Northwind - Because I need a set of rotors & considering these.
Had Hope's in the past but they were never straight.
Most likely to go standard but just weighing up others experiences.
Posted : 28/02/2013 9:25 pm
mikewsmith - Member
Have to say, the ano is both lovely and indestructible, I had one rub slightly due to a fitting mistake (mine) and it barely took a mark. OTOH, the bobbins all came loose, and they were heavier than the Formula plain steel ones I replaced them with.
(OTO,OH, the Formula ones have a habit of wearing unevenly due to the shonky drilling design 😉 )
Posted : 28/02/2013 10:30 pm
