Need to replace the pads in my tiagra (4770) brakes bit getting a bit confused. Are all shimano road pads the same? Anyone got any recommendations?
No. Not all the same. Shimano’s website will help you with the pad type numbers for ones that will fit. Well Shimano ones anyway.
These are the part numbers for the genuine Shimano ones to fit those callipers. I run Y8PU98040 finned resin in my GRX callipers, they use the same pads as your Tiagra.
If you can get sintered pads rather resin I would. My road brakes started with sintered and I accidentally replaced them with resin and I’ve been a bit unimpressed.
I just replaced my front brake with EBC organic (green).. and now.... It. Doesn't. HONK. In. The. Wet!
