Shimano micro splin...
[Closed] Shimano micro spline
9 Users
I hear the micro spline still hasn't cured the alloy freehub scarring issue, has anyone had any experience of the durability yet, might be too early for this question but I hope that HOPE are getting a steel version ready for when they finally get permission to use it.
Posted : 20/08/2019 10:15 am
DT are making a steel microspline freehub, they call it 'Hybrid' as it's intended for E-bikes but it'll fit any DT ratchet hub (350, 240 etc).
Posted : 20/08/2019 12:25 pm
Posted : 20/08/2019 7:44 pm
Hope don’t even make boost hubs
Err.....
https://www.hopetech.com/products/hubs/
Posted : 20/08/2019 7:45 pm
yeah that'll learn me to look before I post! They always used to be just convertible ones. Then I found out there's no delete function on the forum 😀
Posted : 20/08/2019 7:48 pm
No they didn’t, they’ve always made boost hubs. They just happened to offer adapters for people with 142mm hubs along side their boost hubs so people could upgrade without buying a whole hub.
Posted : 20/08/2019 10:21 pm
Why has this topic been hijacked, its supposed to be about shimano micro spline freehub longevity.
BTW Lustyd, its teach me not learn me, I'd edit that post as well.
Posted : 21/08/2019 8:45 am
There's more to language than being correct, sometimes you can convey more by using a "wrong" word. That post says exactly what I wanted it to say, and "that'll learn me" is in quite common usage, but thanks for the feedback.
Posted : 21/08/2019 3:04 pm
endomick: learn or larn is commonly used for 'learn' and 'teach' in the north east, it's dialect and is either Norse or German in origin IIRC. Also, you missed an apostrophe from 'its'. HTH
Posted : 21/08/2019 5:16 pm
I haven't come across this problem, but i will keep a eye on it as i just setup my Shimano XT 12 speed today! thanks for the heads up!
Posted : 21/08/2019 5:26 pm
Well that'll learn me to mess with Lustyd and Joemmo, but you're still hijacking this post and I'm still right, apart from the blatant pisstake, sorry, mistake.
Thanks to Hatter and Hedfree for worthwhile contributions.
Posted : 21/08/2019 6:07 pm
It wouldn't be STW without tangents and grammatical pedantry.
On topic, weren't there rumours of third party attempts to make a patent circumventing but conveniently compatible standard that would take microspline cassettes?
Posted : 21/08/2019 6:31 pm
The freehub scarring issue does annoy me about about the shimano freehub. Filing burrs down is tedious!
I hope there is a wider available alternative. I like the smaller jump between top two rings on the shimano 12 speed. It’s coming round to time to replace my cassette and chain so would be a convenient time to get an extra gear!
FWIW that’ll learn me gets used a lot in the West Country too!
Posted : 21/08/2019 9:24 pm
Yup! The closer ratios and the fact it's Shimano is what drew me towards the XT groupset! Can't wait to give it a ride!
Posted : 21/08/2019 10:37 pm
@Marksnook I've never seen scarring on Shimano - they are the only company not making the freehub out of cheese as far as I knew. All mine are Ti since 1995 and I've never even seen a scratch. I must admit that the move to Alloy for the 12 speed has me a little worried but Shimano engineers generally know what they are up to so I wouldn't let it put me off. Certainly I'd rather have an XTR hub (with Scylence one day!) than a nasty clicky third party one full of angry bees 🙂
Posted : 22/08/2019 9:56 am
I've not noticed an issue with my DT micro-spline freehub.
Had no issues with standard DT Shimano one either so not really expecting any.
Posted : 22/08/2019 10:13 am
I used to munch alloy freehubs, then I got lectured about the importance of doing the lockring up to 40nm and keeping it tight.
Bought a big torque wrench, did as I was told and my cassettes no longer munch my hubs.
Simples!
Posted : 22/08/2019 10:27 am
@lustyd - DT Swiss with a 36 or 52T ratchet is a great sound, not at all like a Hope or i9. Mind you I also have Hopes and the noise is quite a good pedestrian alert for the commute.
It's a shame Shimano couldn't just adopt XD but I guess that was never really likely
Posted : 22/08/2019 11:17 am
