Shimano M785 brakes...
[Closed] Shimano M785 brakes leaking from master cylinder
2 Users
 duir
Just fitted a new set of M785's but noticed they are seeping fluid from the master cylinder seal when the lever is pulled. Anyone else had this?
Posted : 27/01/2013 3:50 pm
Possibly just superfluous fluid from the original fill/bleed process, before the piston can create pressure in the hose, it's primary seal has to pass the port into the reservoir, this creates a little pressure in the reservoir which expands the diaphragm, and will pump out any fluid on top of it (Hope put a note with their brakes to say it's normal).On the other hand, they may be faulty, if it continues then they probably are.
Posted : 27/01/2013 4:54 pm
 duir
Thanks for that, I shortened and then re-bled them myself and then it started. Very familiar with Hopes but these shimano are new to me so wondered if I had done something wrong. However after several wipes and lever pulls the fluid seems to have stopped leaking so it must have been what you said. Ta.
Posted : 27/01/2013 6:13 pm
