Am I right in thinking that you can not buy just the seals for shimano brakes? All I need is the rubber seal that sits under the lid of the master cylinder. I have looked online but all that seems to come up is that you have to replace the whole lot?
Correct
[url= http://si.shimano.com/php/download.php?file=pdf/ev/EV-BL-M595-2908.pdf ]Parts (pdf)[/url]
Item 3 from the above ? Shimano part Y-8U913000
Seems to be available..: [url= http://bicikli.de/shop/SHIMANO-spare-part-Y-8U913000-BL-M775-DIAPHRAGM-Shimano-Code-Y8U913000 ]
1.36 Euro[/url]
Piston seals are a no. As above other parts are available
Yes thanks that is the part I need!
is there not a UK spare part seller?
Can be ordered from virtually any LBS via Madison.
