Shimano levers pull...
[Closed] Shimano levers pulling to bars Help
11 Users
So got the hard tail out of the shed and brakes are not stopping bike, levers are pulling to bars, so tapedup levers to bar, that usually fixes it but for some reason its not working this time, what hydraulic fluid do i need for a top up, or anything else i should look at.
Posted : 20/04/2015 11:49 am
Don't Shimano brakes all use mineral oil rather than hydraulic fluid?
Posted : 20/04/2015 11:51 am
I've had 3 brakes replaced on warranty due to this - I would enquire if I were you
Posted : 20/04/2015 11:52 am
Sounds like it needs a bleed. Shimano mineral oil.
Posted : 20/04/2015 11:56 am
+1 it needs a bleed.
Posted : 20/04/2015 12:15 pm
[quote=tops 5 ]I've had 3 brakes replaced on warranty due to this - I would enquire if I were you
you can get brakes replaced on warranty when they need bleeding? result...
Posted : 20/04/2015 12:16 pm
Top up and a bleed.
Use Shimano mineral oil or LHM automotive suspension fluid.
As stated already, they need bleeding. Use our blog post if you need guidance:
[url= http://www.epicbleedsolutions.com/blog/how-to-bleed-new-shimano-brakes/ ]How to Bleed New Shimano Brakes[/url]
Posted : 20/04/2015 8:48 pm
Did you take the reservoir cap off when you taped them?
I did the same as you just a few weeks ago, but opened the cap too and it was like new a few hours later.
Posted : 21/04/2015 12:59 am
i can't see that it says they are Shimano brakes
Posted : 21/04/2015 4:54 am
The thread title says they are
Posted : 21/04/2015 5:00 am
crapjumper - Member
numpty 💡
Posted : 21/04/2015 6:01 am
