As the title, is there an adapter to fit a Shimano I-spec ev shifter directly to a SRAM matchmaker bracket?
If not is there a mount that goes straight to the bar I can run along side my brakes?
Thanks!
Can't find an adapter, but according to the diagram (
) you will need part number Y0FA98040 (for instance, https://www.sjscycles.co.uk/gear-spares/shimano-xtr-slm9100-base-cover-unit-right-y0fa98040/ ).
If it exists then problem solvers will make it.
I've had no luck finding something, so cancelled the order of the new shifter.
Will try find one with a the bar clamp on it already, thanks for the help!
