Shimano hydraulic b...
[Closed] Shimano hydraulic banjo fittings
9 Users
Anyone know of a Uk source for these?
Really struggling
I know you can buy them already crimped on the hose but I’ve already spent hours threading a length of hose internally and can’t face starting again!
Posted : 22/01/2021 5:24 pm
Tape old hose to new hose, pull through. Sorted.
Posted : 22/01/2021 5:28 pm
Feed a gear cable through the brake hose, remove the brake hose then feed new outer using the gear cable which is already through the frame, shouldn't take more than 5 mins. Not 100% sure about this but I think Shimano brake hoses only come with the banjo crimped at the caliper end, fitted one to a lads bike last year and I'm sure that's what he'd been told when he bought it
Posted : 22/01/2021 5:35 pm
Don't think you can buy them separately other than their party ones.
Posted : 22/01/2021 6:40 pm
They made them when the original 4 pot XT brake around 2000 went from metallic hoses to standard plastic coated hoses, but were discontinued long ago.
As suggested above, thread a gear cable through it and use that as a guide for the correct hose.
Posted : 22/01/2021 6:50 pm
 cp
As above, Shimano ones only come pre crimped to the hose.
Re thread with a new hose is the only option really. It's easy though as above - just make sure you thread something through to guide before your remove the hose you've already threaded.
Posted : 22/01/2021 7:20 pm
Thanks for the replies, I wasn’t really after tips for threading the hose through.
Should have said I’m after 3rd party fittings
Posted : 23/01/2021 9:36 am
There are loads of them on amazon. No idea how well or badly they work, but they do seem to exist.
Posted : 23/01/2021 9:48 am
Not sure if they will fit your hose
https://www.uberbikecomponents.com/category/436/Hydraulic-Replacement-Fittings
If it was me I would just replace with the correct hose and banjo.
Never had a problem with threading one through the frame.
Posted : 23/01/2021 9:49 am
I assumed that the OP had already cut the banjo off an existing hose and threaded the cut end through the frame.
Personally, I'd just buy a new hose and chalk it down to experience, using the cut hose to guide the new one through.
Posted : 23/01/2021 10:03 am
