Shimano Hollowtech ...
[Closed] Shimano Hollowtech II, plastic crank arm clip thingy... Shimano XT
4 Users
Afternoon guys just a quick sanity check.
From what I understand this tab isn't to pinch the cranks up against, more of a safety tab should the cranks come loose.
I've torqued each bolt to 15nm, alternating from bolt to bolt until tight. The plastic tab has far more of a gap compared my previous Shimano X9's, can anyone have a quick look on theirs and see what sort of gap there is?
[URL= http://i237.photobucket.com/albums/ff100/capoz77/IMG-20150509-WA0030_zps4puhaqsu.jp g" target="_blank">http://i237.photobucket.com/albums/ff100/capoz77/IMG-20150509-WA0030_zps4puhaqsu.jp g"/> [/IMG][/URL]
Gap is almost equal to another plastic tab in thickness.
Posted : 10/05/2015 11:28 am
Yep, just a safety tab to stop the cranks falling off if they come loose. If the two bolts are tightened evenly to the correct torque (12nm I thought, but whatever it says on the crank) then you're good.
Posted : 10/05/2015 12:15 pm
The gap doesn't matter - its not a spacer, just a safety tab as per drover's response. You can run the cranks without it.
Posted : 10/05/2015 5:33 pm
I've checked two different models on my bikes and visually there's a difference
One looks like yours, the other seems to be much closer, same torque wrench used
As above^^
Sanity check complete
Posted : 11/05/2015 4:43 am
