So I decided to break the rules and disassemble my Shimano BB. It had seized solid and I guessed I had nothing to loose. It came apart easily and after a good clean and a good dollop of fresh grease it's now smooth as silk.
That is all.
What did you use to get it apart?
Yeah, those plastic outers crack very easily (I had a spare BB that I experimented with first). I used a small screwdriver and eased it out from the inside. Worked a treat.
You can get a set of those picks for less than £2 on fleabay.... money well spent!
While we're on, can anyone recommend a good cheap tacky waterproof grease for bearings?
scapegoat- water pump grease from a boat shop or chandlers if you're posh.
chandlers it is then old boy. 😀
