Shimano cranks sing...
[Closed] Shimano cranks single ring
8 Users
Pondering a move to going 1x on the bike. Currently 2x deore cranks with a 104 bcd. Looking at 30 or 32 chainring from superstar but vaguely recall there being some difficulty with shimano and small chainrings.
Posted : 07/12/2020 2:26 pm
I use 30T on both Shimano and Sram cranks ,(both 104BCD). Have had no problem at all with a variety of makes from Hope, Superstar and On One. The chain can get close but it misses. 10 speed by the way.
Posted : 07/12/2020 2:35 pm
Should be OK, but you probably can't get an oval ring.
Posted : 07/12/2020 2:38 pm
32t should be fine.
You can get 30t round or 32t oval, they have stand-offs and threaded holes built in to keep the chain away from the arms and are usually a few quid more. IIRC Absolute black did a 30t oval at one point but it looked a bit of a faff with smaller bolts and eccentric nuts and inserts on the smaller pair of bolts.
Posted : 07/12/2020 3:14 pm
Should be OK, but you probably can’t get an oval ring
I haven't looked but I'd assumed oval rings would work with those "asymmetric" Shimano cranks (like the M8000)?
Posted : 07/12/2020 3:19 pm
Was looking at the superstar 30t,its threaded and looks to have the spacers machined in. Mostly peak district so would be lookin at an 11-42/46t cassette to retain the climbing ability. Currently an 11-36 cassette 2x10.
Chainring
Posted : 07/12/2020 3:29 pm
I haven’t looked but I’d assumed oval rings would work with those “asymmetric” Shimano cranks (like the M8000)?
only those with the BCD to fit.
The Deore should just be 104bcd "square/equidistant"
Posted : 07/12/2020 3:43 pm
I use a 30t on a Shimano crank, 104bcd, no problem
Posted : 07/12/2020 3:46 pm
Couldn't find one for my M7000 chainset when I looked, but that's not a categorical "no" obvs.
Bit of a headscratcher what the practical benefit of asymetic bolts were for Shimano.
Yes, I use them and they work fine, with the added benefit of idiot-proof installation as you can't get them 90 degrees out.
Posted : 07/12/2020 6:43 pm
Looking at the 30t round from superstar and presumably need these Chainring bolts
Posted : 07/12/2020 9:48 pm
Why would the assymetric positions make bolts work loose? I've had oval on M8000 a few years with no issues. Various folk sell them inc Absolute Black
Posted : 07/12/2020 10:54 pm
Nope, just re-use the ones you take out (without the nuts obvs).
Posted : 07/12/2020 11:01 pm
