So looks like another set of SLX M675s brake calipers are shot, need constant cleaning and I'm getting constant howling and poor breaking. But, not really wanting to shell out on more replacement calipers (cheapest UK are about £32 each) and 'cheap' decent brakes don't seem to exist anymore (got a pair of new Deore M615s for £45 on ebay about a year ago), has anyone got a set of those replacement pistons for about £8 you can find on ebay and had any success with replacing and curing the leaky pistons?
I got replacement calipers(m7000) from bike discount for £21.60 each. Just buy lots of them to negate the postage charge, you'll need them anyway ☺
My front M615 has just given up for the 2nd time, you got a link to the eBay piston kit?
Don't see any harm in giving it a go if they are available.
Just remeber to remove & get in behind the seals with an allen key that is a good fit, scrape round the seal reccess/seat to clear out alloy furry corrosion & crud that pushes the seal tighter on the piston.
Really important.
Here's a link to some
My same type XT and M615s have been fine so far so hope they stay that way.
One thing I did recently to the SLX set that's just started playing up was to push the pistons out a bit, clean them and lube them then push them back in, now I'm wondering if doing this brings out the problem, maybe better to leave them alone? But, I've done similar things with older generation calipers without getting problems, my SLX M665 are 8 years old and no problems at all.
Buy in bulk, might just do that!
