Shimano brake pad s...
[Closed] Shimano brake pad snap ring
4 Users
Anyone know of an alternative to the snap rings on Shimano XT disc brake pad retaining pins? Had a look on various fastener websites.Nearest I can find are what are described as r clips,but can`t find any small enough. The Shimano ones are 12mm long.
Shimano ones are a rip off at £2 each..........
Posted : 11/05/2012 9:02 am
Could use a split pin instead of the pin & clip, like the SLX does. Or have I missed the point completely....?
Posted : 11/05/2012 9:43 am
Thanks will go see what I can find in Halfords.
Posted : 11/05/2012 9:48 am
I use the rubber o-rings (donuts) that go on gear cables.
Assuming you mean:
One of [url= http://tinyurl.com/dylltnq ]these[/url]
Posted : 11/05/2012 9:55 am
Have you ever had a pad retaining bolt come loose? No me neither. I've not had those little clips on since the first time I took the bolt out and the clip sprung off and I didn't bother putting it back on.
Posted : 11/05/2012 10:04 am
[i]Have you ever had a pad retaining bolt come loose?[/i]
Yep, in the Alps. And the pads bounced out. Had to bodge a cable tie to hold them in the rest of the trip.
Posted : 11/05/2012 10:05 am
Probably not an issue,but I regard it as cheap insurance against me absent midedly failing to tighten the retaining pin!
Dez B,Yep that one.
Posted : 11/05/2012 10:54 am
[url= http://www.ebay.co.uk/itm/SMALL-R-clips-1mm-x-16mm-pack-8-LP10-/290612110081?pt=LH_DefaultDomain_3&hash=item43a9d4e301 ]r clips[/url]
Found these on ebay: http://www.ebay.co.uk/itm/SMALL-R-clips-1mm-x-16mm-pack-8-LP10-/290612110081?pt=LH_DefaultDomain_3&hash=item43a9d4e301
A tad longer,slightly thicker but look like they might do the trick.
Posted : 11/05/2012 10:58 am
