Shimano 6700 sti re...
Shimano 6700 sti return spring - where from??
6 Users
6 Reactions
Got an ultegra equipped bike in with a knackered return spring - only thing wrong with the shifter!!
Anyone know of any/whereabouts
Posted : 11/05/2023 9:54 am
It doesn't look like they were available as a spare so tracking one down could be tricky
Posted : 11/05/2023 10:27 am
I'd seen that 😭 but their is one for the 6870 y00s000b0
Posted : 11/05/2023 10:33 am
They are generally not fixable.
Posted : 11/05/2023 10:37 am
If the return spring can be had it's fixable
Posted : 11/05/2023 10:59 am
Is the part you need in this photo?
[url= https://i.postimg.cc/zvWRdMJB/PXL-20230511-100229844.jp g" target="_blank">https://i.postimg.cc/zvWRdMJB/PXL-20230511-100229844.jp g"/> [/img][/url]
Posted : 11/05/2023 11:03 am
No, it's the double ended coil in the shifter part for the left double shifter
Posted : 11/05/2023 11:10 am
OK, is it in this photo?
[url= https://i.postimg.cc/gcxSbFmT/PXL-20230511-102146835.jp g" target="_blank">https://i.postimg.cc/gcxSbFmT/PXL-20230511-102146835.jp g"/> [/img][/url]
Posted : 11/05/2023 11:22 am
I have a 685 lever with the same issue. At least it's the LH shifter so the pair is good for 1x, but it's so frustrating that for the lack of a tiny spring a shifter can be bricked.
Posted : 11/05/2023 11:36 am
Yep that's the badger
Posted : 11/05/2023 11:39 am
PM me your address
Posted : 11/05/2023 11:41 am
I ran into the same problem, and I solved it by cutting a few coils off the end of the spring, then using pliers to bend a new "hook" on the end of it. You have to make sure that the new hook has roughly a 0° or 180° orientation to the hook on the other end, or the spring can twist itself loose once installed (I made that mistake). Make sure that the lever part which the spring pulls on will retract fully after being actuated, and you should be good.
I created an account just so I could make this reply!
Posted : 14/06/2024 12:10 am
