Shigura time - barb...
Shigura time - barbs and olives?
8 Users
4 Reactions
Fed up of my Shimano calipers, and I happen to have two Magura calipers in the spares box....
Are the Magura barbs and olives any different? The plan is to keep the Shimano lever and cable - the change to Magura is at the caliper end. This is different from what lots of folk have done, but my Magura calipers have damaged cables....
Posted : 01/08/2024 12:24 pm
You will be fine using the Shimano ones Matt, done it several times
Posted : 01/08/2024 12:25 pm
Excellent.
Posted : 01/08/2024 12:27 pm
Think I used Magura on Magura hoses, worked fine also.
Posted : 01/08/2024 12:34 pm
you don't use a barb and olive at the caliper end, though? The fittings are crimped on at that end?
Posted : 01/08/2024 12:48 pm
reeksy and reeksy reacted
ah, looking at pics of a few magura calipers, looks liek their fittings are not' crimped. Nice.
Posted : 01/08/2024 12:49 pm
Yep - our MT5's are bolt/crimp in... 8)
Posted : 01/08/2024 3:10 pm
The other option is jagwire hoses. They make a kit that uses the same hose and different end adaptors. You match the adapter to the caliper/lever so that's correct and the hose works as it should with the ends. Not the cheapest option though
Posted : 01/08/2024 3:24 pm
Magura hoses, barbs and olives here on Zee levers with good results.
Also had Shimano fittings on Magura hoses for a short while, but not long enough to judge looking term effectiveness. Worked fine while they were there though.
Posted : 02/08/2024 10:58 pm
As above the fitting is different. I bought a magura fitting hose on ebay that has been fine.
Posted : 03/08/2024 3:52 am
 Neb
Uberbike hoses worked well for me. Shimano fittings on one end and magura on the other.
On magura hoses the inner diameter is a little bigger so I'd heard that using magura barbs is a little more secure.
Both bikes set up as shigura, genuinely the best brakes I've used. But you may take a wee while to get used to the bite...
Posted : 03/08/2024 7:37 am
