Hopefully someone that lives in Sheffield or somewhere similarly lumpy can give me a simple answer on what singlespeed ratio I should be aiming for on my hack (700c drop bar). I have a 36 tooth ring I'd like to re-use.
I previously used the bike fixed when I lived in Somerset but am not man enough to ride fixed up here.
On my 9 speed 26" luddite mtb that spends its weekends going up and down Wharncliffe I have a 1:1 as the easiest gear and can normally get up the climbs without resorting to this. and I appreciate that singlespeed is meant to be hard.
Any advice gratefully received.
36x15 (64") should do you. I use 42x17 (64") single speed around Sheffield.
I toyed with the idea, but soon discovered that any gear that was useful on the flat couldn't get me straight up Upperthorpe and Springvale Road.
Clearly I am not man enough to ride a singlespeed in Sheffield, so opted for a 5spd hub gear instead.
Cheers for the replies, I just ordered myself a 16 and will see how I get on, especially as I have to deal with the roads "theonlywayisup" mentions.
I ride 44-18 in Sheffield (700C).
Bit spinny on the flat and occasionally brutal on the hills, but it's versatile enough that I can get everywhere if I choose my route. Not always possible to go direct. For instance on the odd occasion I have to ride from Hillsborough to Crookes - there's no way I can manage straight up the hill, so I generally go via Netherthorpe, Weston Park and Broomhill.
I did however stomp up Blake Street last summer, just to prove a point. I'm just not exactly sure what that point was, and to whom I was supposedly making it. I think I was expecting ranks of beautiful women lining the road, swooning at my masculinity or something. Instead I just ended up falling into the Blake for a pint, which I drank alone and in silence, to no perceptible fanfare.
jackthedog, your story has touched me like none other.
Get a rear gear hub.
I have used 22:16 on 700 fixed, you can ride up anything on that but you wont get there fast and 34:17 on 26" which gets you there faster but means you have to walk. I too have detoured via netherthorp to get from the 'bro to places otherwise I go blind with effort
I should have added that I was on a 26" MTB* with 1.75" slick tyres, so you'll do better on 700c wheels.
Good luck, and I'll remember to say "hi" if I see you gurning up Upperthorpe or Springvale.
* 26" being the correct wheel size for a real MTB 😉
I'll probably just grunt at you!
You're quite right about MTB wheel sizes, my 1x9 26" P7 is a delight. This however is a 1970s Claud Butler Cresta tourer which is a superbly balance thing that looks nothing special so can happily be left locked to lampposts outside pubs and the like.
