Shed question
[Closed] Shed question
6 Users
Thinking of building/buying a good quality garden shed.
I have room for roughly 12x30 ft so not going to be cheap.... But cheaper than a garage and don't need planning permission..
Using it as a workshop/storage etc...
With good quality wood and treating it yearly, could I expect it to be good for 20 years or so?
Posted : 30/06/2017 9:04 pm
Pressure treated timber lasts very well these days. As long as its designed so water doesn't collect somewhere and its reasonably ventilated then it'll likely be fine. You shouldn't need to keep retreating it.
Also you may not need planning (although worth double checking) you will likely need building regs sign off
Posted : 30/06/2017 9:08 pm
The timber should be ok as long as it's from a half respectable seller. Depending on the quality of a pre made shed I'd suspect the roof covering may end up being the weak point. All mineral felts are not made equal for example. Epdm rubber roofs are gaining ground on felt as it can be sourced in bigger sheets helping to eliminate seams that end up leaking.
If you DIY, go above and beyond with things like sealing cut ends, pre drilling so you don't split the grain apart etc. Tanalised is great but as soon as you compromise the outer layer it's just a matter of time, no matter how good the timber was to begin with.
Try to plan ahead with your design, you may be able to make it so that the worst spots for rot are easy and cheap enough to replace.
Don't scrimp on the timber treatments. I've found the cheaper options are usually a false economy. Do it right once and you'll be able to spend more time enjoying it and less time repainting.
Like Nick says, ventilation is key. Try get some up at roof level and some lower down as far away as feasible. The temperature difference between the two will help drag air across the shed keeping it reasonably dry.
Posted : 30/06/2017 11:03 pm
I bought a Beast http://www.beastsheds.co.uk/security-sheds shed 6 years ago. Just thinking about giving it a wood treatment now - its fine, but could do with a little tarting up.
Posted : 30/06/2017 11:19 pm
Those beasts look very well made. What's it like 6 years later ? I.e are things drooping etc where they have been through 24 "seasons " ?
Posted : 01/07/2017 9:22 am
Do it double skinned with a membrane. The inner frame and walls will see you out. The cladding you can replace every 20 years.
Posted : 01/07/2017 9:39 am
