Obviously I lucked on getting it right last time but after replacing my crankset (old square taper deore thing for a truativ noir and hope chainring) I can't get it even close to running right.
Any tips on how to set a superstar top guide so its quiet and doesn't rub???
Throw it away and buy an e13
Throw it away and go single speed.
A) not spending 75quid on an e13 one
B) done SS before and not doing it again!! 😳
Side rub or top and bottom?
If it helps ended up shimming my m part one with brake shims between the cage and the arm.
Mpart guide + shimano crank - fail.
If i had iscg mounts I would spend the extra!
Side mainly. But got too cold to carry on faffing 😳
Most guides I've fitted ended up having to be adjusted with shims and or bent grinded beaten
Into a shape place where they don't rub
But worth the time to make them silent
This:
My superstar on is also shimmed, bit of plastic and some cut up inner tube.
Got a pic of the setup?
Bike is in the car, will got take a pic at lunch time.
That looks like the same moulding as the m part cage. Iirc changing the angle helped as there are wide and narrow bits in the opening.
Failing that Might need to file it or ignore the rub.
