Setting up a DHX5.0...
[Closed] Setting up a DHX5.0 Coil
6 Users
Got one on my Heckler, and really don't know if I've set it up right..
I don't seem to be getting a decent amount of travel from it..
Ive the right size spring, but know I'm struggling...
Anyone got a(n) [s]Cruzheckler[/s] idiots guide?
Cheers all.
Posted : 01/01/2012 6:14 pm
Where's flow when you need him?
Seriously, zip-tie round the shaft (of the shock 😉 ) to check travel, otherwise damping etc depends on how/what you ride?
Posted : 01/01/2012 6:20 pm
i sent mine to loco and then spoke to si at 18 bikes.
run lots of rebound 6 clicks
155psi in the boost valve
no propedal
Posted : 01/01/2012 6:27 pm
There is an excellent tutorial video on pinkbike. worked wonders on my session. shojld be easy to gind, but i am on phone now
Posted : 01/01/2012 6:39 pm
Cheers All... That's this afternoons job squared away then..
Posted : 02/01/2012 9:34 am
I found on mine that it performed better with a softer spring than what was recommended for your weight, on my Heckler for my weight supposed to have been a 450lb but as you say it never used full travel so I went to a 400lb and a Push Tune at TFT made a big difference for me, only ever used one click of pro pedal, best shock for the heckler, 🙂
Posted : 02/01/2012 10:50 am
