Setting front mech ...
[Closed] Setting front mech for double and bash?
6 Users
I've put a 32T bash on the outside with a 32T middle ring, but how do i now set up my mech? any tips?
Posted : 01/11/2010 2:13 pm
Same place as for a triple, just wind in the limit screw on the mech so you can't shift passed the middle (now outer) ring.
Posted : 01/11/2010 2:18 pm
yep, what he said, just had to wind it all the way in on my SLX front mech.
Posted : 01/11/2010 2:19 pm
Cheers, no front mech on at the moment, so will have to put the 44T outer ring on to set up, then replace it with bash, then adjust mech to not go past middle ring. Is this correct?
Posted : 01/11/2010 2:30 pm
Yes, its tricky to get the height right with just a bashring on. Set it up for triple then wind in limit stop.
Posted : 01/11/2010 2:34 pm
Thanks
Posted : 01/11/2010 2:46 pm
I ran mine a little lower, most people say not to but I got equivalent shifting with less chain noise so I was happier that way. my advice is don't worry about getting the height "right", the normal position's essential for 3 ring shifting but doesn't seem to be all that criticial for dual.
Posted : 01/11/2010 3:00 pm
I find the only problem is the height
really hard to get to clear the bash ring and be low enough so that the chain doesn't rub when on the granny ring
Posted : 01/11/2010 3:09 pm
