Hi,
I'm going to attempt to service my Revelation forks this evening and I've got a service kit off ebay that contains the neccessary fluids and O rings etcs.
The kit contains O rings for both the air spring and the damper. How do I know which O ring goes where? I've got the SRAM service doc but it literally says 'replace with a new O ring' rather than list a particular size. I suspect I won't be able to use the old ones for comparison as they would have stretched.
Thanks.
I've never found an o-ring I couldn't look at and just tell which matches during a service.
As the man says, they're either interchangeable or so obvious that you needn't worry.
