servicing marzocchi...
[Closed] servicing marzocchi 55 tst2 2008 forks?
7 Users
 ton
got some of the ill fated forks.....they wont give any travel up even with the air chamber empty.
are they worth sending for servicing or should i bin them.
this model
Posted : 16/05/2012 8:03 pm
probably hydrolocked damper, can't remember the exact fix but try searching on MTBR forum. It was a common problem.
Maybe this (you need to log in to see the pics):
http://forums.mtbr.com/shocks-suspension/tst2-bleed-alternative-w-pics-410888.html
Posted : 16/05/2012 8:05 pm
 ton
which company is the best to use for servicing them.
that looks far to difficult for me to do.
Posted : 16/05/2012 8:20 pm
windwave tony. that's who did mine (granted, under warranty but still)... most of the other big name servicing companies won't touch them anyway.
Posted : 16/05/2012 8:31 pm
 ton
cheers mate.
Posted : 16/05/2012 8:33 pm
TBH the procedure there isn't that hard. I've done it on a pair of hydrolocked XC600 TST2s in a carpark before a ride using an adjustable spanner and a rag.
Posted : 16/05/2012 8:46 pm
 ton
just did this, and the forks seem ok now.
cheers all.
Posted : 18/05/2012 1:21 pm
 hora
ton do you still have these forks? There is a shim stack mod that turns this fork into something amazing. Mine spiked on rocky hits- then did them mod and they are now biblical.
http://forums.mtbr.com/shocks-suspension/marzocchi-55-tst2-conversion-shim-damping-step-step-410874.html
Posted : 31/08/2012 7:53 am
Hi hora, where did you get the shims for the conversion of these forks? I fancy doing it to mine cheers Chris.
Posted : 03/03/2013 9:01 pm
I have the same forks, ata valve failed twice. Windwave converted them to a coil free of charge. You'll still be able to use the but not have the tuning possibilities of air. travel adjust will be about 15mm after and only a max of 25Psi in the lower leg.
Posted : 03/03/2013 11:37 pm
