Servicing Hope ProI...
[Closed] Servicing Hope ProII bearings & RS Reba Forks
3 Users
Hi guys,
I am in the middle of building a bike up for my 13yr old son. I am using my old hardtail as a parts doner and some of the bits need a bit of care.
I know i have seen service guides for both so if anyone can find me a link it would be appreciated. I have done the search but it doesnt give any results.
Ta
Posted : 09/06/2016 8:57 am
https://www.sram.com/service/rockshox/7,103
Lower leg service is pretty straight forward, if they're solo air & you service the air shaft then use as little grease as possible as this can exacerbate the "stuck down" syndrome.
http://www.hopetech.com/how-to-videos/
Posted : 09/06/2016 10:24 am
Thank you 🙂
Posted : 09/06/2016 11:25 am
Pro 2 service is dead easy with the correct tools, they make it dead easy to knock the old bearings out and press the new ones in without damaging them.
If you don't have a fleet* of bikes adorned with Pro 2's then I'm sure you'd be abel tof ind someone to borrow the tools off.
"quiver" or "stable" would also be accepted
Posted : 09/06/2016 11:46 am
